Where can i get rubber hose that connects blower to pipe?
Old May 8, 2004 | 07:20 PM
meccanoble's Avatar
Sports Button FTW
just wondering if anyone ever had to buy a new one or went intercooler setup and doesnt need there's. Mine has a crack causing boost leak and i want to replace it. Was wondering why i only seen like 8 psi tops! . I'm going to try Home depot or autozone on monday but just wondering if anyone either has an extra one or knows good affordable spot to get one. Its the 90 degree elbow type hose that connects blower to the pipe that runs down the front of the engine bay.
Old May 8, 2004 | 07:58 PM
BigDogJonx's Avatar
your not going to find that in Homedepot thats for sure. You need to get yourself a 90degree silicone elbow coupler. That is probably going to run you around 50-75 depending on who you get it from. Those 90s are expensive because of the elbow. The straight couplers are usually 20-30 because easier to make.
Dixit
Old May 8, 2004 | 08:00 PM
BigDogJonx's Avatar
http://www.turbohoses.com/90%20Degree.htm
EXPENSIVE!!!!
Old May 8, 2004 | 08:02 PM
BigDogJonx's Avatar
http://www.alamomotorsports.com/bp/elbow.html
Much cheaper place.....
Old May 8, 2004 | 08:03 PM
BigDogJonx's Avatar
http://www.bakerprecision.com/purosil2.htm
Another place which is also cheaper...
Man I got racks of links....
Old May 8, 2004 | 08:05 PM
BigDogJonx's Avatar
http://www.ptrsds.com/90%20Degree%20...ne%20Hoses.htm
And finally the last one.
Old May 9, 2004 | 01:12 AM
meccanoble's Avatar
Sports Button FTW
Originally Posted by BigDogJonx
Dixit to the rescue!!! Thanks man! Which size do i need though? i'm probably not going to get to measure until monday morning cause of work tomorrow. I'm thinking 2 1/2 on one side maybe 2 3/4 on the other? I dont think these sites have them in multiple sizes per coupler. I guess i can take a super sized steel tightening thing to keep it tight?
Old May 9, 2004 | 12:26 PM
BigDogJonx's Avatar
"super sized steel tightening thing" - Is that a newbie technical term?
BTW, you cannot over tighten that thing to make it fit to the pipe, its not going to work. Need to get the same ID size for each side of the 90
Dixit
Old May 9, 2004 | 12:48 PM
JAY25's Avatar
if you dont have the funds, just use some silver tape and wrap it around until you can get you a good rubber coupler
Old May 9, 2004 | 02:10 PM
iansw's Avatar
YOu can also just call Stillen and they'll send you one for $20.00
That's what I did - it also is better because it has the flat edge at the back of the coupler at the hose, leaving room for your headlight harness to fit in there.
Look in the Sticky in this forum for the Part number.
Old May 9, 2004 | 03:41 PM
meccanoble's Avatar
Sports Button FTW
my hero!!! Thanks ian, i'm going to hit them up. I hope this isnt another "its this cheap" and then i call them and its really 3 times the price...like the S/C rebuild
Thanks to all that have helped.
Old May 9, 2004 | 05:08 PM
chris'smax's Avatar
I may be wrong but I think the silicon couplers are reducers. I think on my v2 they call for a 2.5 to 2.75. I checked in to getting some new ones as well and they are pretty pricey.
Old May 10, 2004 | 10:03 AM
meccanoble's Avatar
Sports Button FTW
yes in f*cking deedy! 75 mother father dollars!. It is 2.5-2.75". I'm going to try local shops and see if i can get something. Dixit, i cant tighten it? it has to be a perfect fit? i cant use a steal clamp to tighten the hose onto the blower? like i do on the throttle body?
Old May 10, 2004 | 10:13 AM
BigDogJonx's Avatar
To put it lightly, hell no you cant tighten down 1/4" with a Tbolt clamp or worm hose clamp on a silicone coupler. Its not designed to do that.
Has to fit exactly.
Dixit
Old May 10, 2004 | 10:06 PM
meccanoble's Avatar
Sports Button FTW
i checked the websites and none of them seem to have a hose with 2 different sizes like we need. I'll call them up tomorrow...but looks like i may have to go the stealin route...
Old May 11, 2004 | 09:23 AM
meccanoble's Avatar
Sports Button FTW
dammit, i called them all and none of them sell them in two different sizes....
Old May 11, 2004 | 10:30 AM
|Bijan|'s Avatar
UCF Lexus
haha, tell me about it. you da man D!
shilov
Feb 19, 2024 09:40 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
conansriver
Nov 18, 2015 02:46 PM
catalinvint
Sep 16, 2015 07:48 PM
