What do your think I should get for my 95 MAX,stock platinum plug or iridium!!
Old Jun 9, 2004 | 10:55 PM
96_vqmax's Avatar
Since I'm going BOOST soon,just want to know what the different plugs can do to an NA form for now(I want to Max out in NA form with I,E,Y,UR pully,MEVI,and ECU before I boost),good or bad?Cause I don't want to waste extra $$$ toward plug while I can BOOST earlier.If you know pls let me know,thanx alots!
Old Jun 10, 2004 | 09:08 AM
Stephen Max's Avatar
If you are going to boost in the near future there is no point in buying expensive plugs since you are going to have to run at least one step colder plugs when you boost. The best plugs for boosted applications are the copper NGKs, and they are cheap. Buy a set of BKR5E-11 for now at $2 a pop, then switch to BKR6E regapped to .034" when you are boosted.
Old Jun 10, 2004 | 10:54 AM
matty's Avatar
What brand are teh BKR5E-11's ?? Where to buy ??
Im in the same situation, I need plugs now but Im boosting in the next month
-matt
Old Jun 10, 2004 | 11:56 AM
MAXimumHP's Avatar
NGK You can get them at Napa, there may be somewhere cheaper though...
Edit:
I found this pretty helpful:
http://jime.homeip.net/Plugs.html
Old Jun 10, 2004 | 01:12 PM
matty's Avatar
Just got back from Strauss Auto...Plugs were $10, we'll see if that fixes my very bad hesitation I am getting http://forums.maxima.org/showthread.php?t=316304 Read UP
-matt
Old Jun 10, 2004 | 05:38 PM
96_vqmax's Avatar
Thanx Stephen Max,so the BKR5E-11 is as good as the stock platinum or close for less $$$?How long will it last if I get all the NA mods for a few months,then I'll go BOOST?Where do you find it for $2 a pop at?I just came back from Auto zone and they said they can order it and it's $4.20 a pop.
Old Jun 11, 2004 | 12:47 AM
stephenlc's Avatar
Order online Frank, when are you doing the install, I would love to be there. The plugs are copper I believe so they last about 20,000 miles. I thought you bought another 4th gen. Your going to do it to your car with the mevi.
Old Jun 13, 2004 | 01:39 AM
96_vqmax's Avatar
So Steve,do you know where they sell it for cheaper?Yeah I just got me another 95 5sp SE,but it need a little work,and I'll prolly swap the MEVI from the 96 Auto into the 95.I'll drive the 95 for a few months with NA/MEVI/ECU to see how fast in NA form before I go boost,I already got walboro 255 in the tank.So are you going to custom your turbo or just buy a kit?I'm thinking buying a kit,but don't know which kit I should get?I might call you later if I go custom turbo,maybe you and me we should go custom turbo to save $$$.
Old Jun 13, 2004 | 06:07 AM
stephenlc's Avatar
I am going custom, I just just thinking and planning on how to run the piping, because that it almost the hardest part. I just got a VAFC, I am looking for 555cc injectors and 300zx MAF.
schmellyfart
Sep 25, 2015 04:47 PM
JoeWhit
Sep 20, 2015 08:01 PM
lowpost99
22
Sep 2, 2015 04:38 PM
cstrasz
Aug 27, 2015 08:07 AM
maxinout93
Aug 20, 2015 02:17 AM
