J&S with emanage?
Old Sep 10, 2004 | 01:07 PM
  #41
sx7r's Avatar
Originally Posted by IceY2K1
Again, does the J&S directly via ignition pulses control timing or indirectly via tricking the ECU by causing a knock signal on the "tapped" knock sensor wire?
it'd have to be directly, otherwise how would the "retard individual cylinders" function work? If it was just tricking the ECU, it'd be alot easier to install as you wouldn't need to intercept ignition signals.
Old Sep 10, 2004 | 01:15 PM
  #42
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Good point. Thanks.
Old Sep 10, 2004 | 02:50 PM
  #43
MardiGrasMax's Avatar
John,
You said the factory ECU will retard at high rpm/noisy instances, so why not eliminate that connection and just use the FACTORY knock sensor in the factory location for the J&S?
I understand about knock sensors being tuned to a particular frequency for a particular engine. No, need for another one besides stock.
AFIAK the maxima ECU ignores the knock sensor at WOT.
It controls it directly.
Old Sep 10, 2004 | 03:14 PM
  #44
IceY2K1's Avatar
Thank you Mardi, sx7r, and especially John for taking time to answer our Maxima dreams.
Finkle
Sep 27, 2015 09:53 PM
95CustomMaxima
Nov 26, 2004 07:41 AM
MaDMaX024
Oct 22, 2004 09:10 PM
BigDogJonx
Feb 26, 2004 04:18 PM
