Looking at a SC this weekend HELP!
I'm looking at a supercharger kit this weekend (v2) with 45,000 miles on it and it's never been rebuilt. Oil every 3k and it comes with a blowoff valve, 3 gauges (boost and 2 others) and he said everything's working fine and all is included. What should I be looking for as far as problems with this kit or obvious places to look for damage/wear.
Basically what questions would you ask this guy.
Thanks a millions!
Thanks a millions!
The best way to determine the health of a blower is to listen to it while it is running. Unfortunately that is usually not an option since most sellers have the kit already removed from their vehicle.
Check for axial play in the impeller. There should be none, nada, zilch. The bearings should feel absolutely smooth as you turn the impeller. There will be a little rotational play in the impeller when you rotate it back and forth due to clearance at the spur gears. I know that is the case for the V1 with the straight cut gears. With the helical gears in the V2 there should be very minimal play, but I haven't ever had a V2 to play with so I don't know what is normal.
Check for signs of oil leaks around the drive shaft and at the joint between the two housing halves. A little oil is probably okay, but it shouldn't be filthy.
Check for signs of oil inside the scroll or pressure piping, which would indicate oil leaking past the inner shaft seal. You don't want to see any at all.
A kit with 45,000 miles on it should be in very good condition if the former owner was religious about oil changes, and especially if he wasn't overdriving the impeller with a small pulley.
What is "standard" rebuild mileage? Or is there one?
He did say that it should last 100,000 miles or more if taken care of properly. Mine has about that much and it has no problems.
VERY true, does anyone have a parts list i could look at to make sure i have EVERYTHING needed to get this thing installed, i am gonna be checking it out this weekend and just want to make sure EVERYTHING is there so I am not making runs to the hardware store every 15 minutes.
James92SE
142
01-02-2024 09:23 AM
06-06-2017 02:01 PM
