Alcohol injection
Old Sep 22, 2004 | 10:46 AM
Drjmaxx88's Avatar
Alcohol injection
Is anyone running alcohol injection with there FI system?
Old Sep 22, 2004 | 03:00 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Y2Kevse is/was when it was SC'd
Old Sep 22, 2004 | 05:47 PM
hlh0501's Avatar
I have a progressive map-based meth setup, but it won't be filled for a couple more days (weekend!)
Then it's time to advance timing, and up the boost significantly.
Old Sep 23, 2004 | 09:47 AM
Drjmaxx88's Avatar
Cool. Im thinking of running this setup in lue of an intercooler. For my little max it might overkill to have the intercooler so I was looking into alternatives. HLH is your car the one that dyno'ed at 400+hp and 500+tq?
Old Sep 23, 2004 | 11:22 AM
hlh0501's Avatar
Yes on my old turbo. You could probably get away with that, how much boost are you going to be running - and what is supplying the boost?
If you do decide on using alc or meth in place of an intercooler, I highly suggest a map-based setup regardless of the increased cost.
Old Sep 23, 2004 | 01:42 PM
Drjmaxx88's Avatar
Im only trying to run maybe 7psi. The turbo is gonna have an internal wastegate. Probably a T3. I need it to fully spool up around 4000rpm. I want a T3/T4 or a TO4 but I don't think it will work to well for the VG30E.
Old Sep 23, 2004 | 01:48 PM
[maxi-overdose]'s Avatar
he still does after switching to turbo.
Mardigras is running it too and he has a recipe of building your own boost referenced water/alcohol injection for ~300 dollars.
Quickgtp
Apr 13, 2017 03:30 PM
cruce91
Sep 20, 2015 10:23 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
98MAX
Mar 16, 2001 10:45 PM
SMX
Mar 6, 2001 08:36 PM
