Opinions wanted on my new SC set up
Old Sep 23, 2004 | 12:52 PM
JustMaxin96's Avatar
Just got a V1 SC kit for my 96 5-speed. I would like some opinions on my set up. I would like to know if I will be safe at 10 PSI with stock injectors.
The set-up is as follows:
3.125 Pulley
8:1 FMU
AEM FPR
Walbro 255
CAI
Stock injectors
SAFC
Mods already installed (that matter):
MEVI
Y-pipe
catback
What are your thoughts? Dangerous lean conditions? Slow? waste of money?
It is the same set-up that Kenneth from the .org had on his max minus the MEVI.
Thanks for the help guys!
Old Sep 23, 2004 | 01:08 PM
Bags's Avatar
VG Ridah's Biatch Hoe
With the 8:1 that is too much fuel pressure,your injectors may lock up, but if you adjust your base FP with the FPR, maybe not.
Many people use the 6:1 disk @ 10 psi.
Old Sep 23, 2004 | 02:25 PM
Thanks for the reply, so if I use the 6:1 FMU would I still need to adjust my base fuel pressure?
Please keep the replies coming.
Old Sep 28, 2004 | 10:38 AM
can some supercharged guys please give me some opinions on my set up? Thanks so much.
Old Sep 28, 2004 | 11:25 AM
Stephen Max's Avatar
That is similar to what I was running for a while, except I had a 3" pulley. I think you'll be okay. Less fuel pressure is safer, of course, which is why people convert to larger injectors instead of upping the fuel pressure when they start getting to the 10 psi threshold.
But, I tested a couple of my old 4th gen injectors up to 150 psi with no sign of lock up. That doesn't mean an old, tired injector won't lock up at 100 psi, of course.
Old Sep 28, 2004 | 12:55 PM
So am I fine with the 8:1 FMU? I am sort of worried of running lean in the upper RPM's because of the MEVI. The most amount of FP I want to see is 100 PSI on stock injectors correct? I have about 180K on these injectors and motor I would really like to run 10 PSI on the stock injectors. Would I be better off just running the larger 3.33 pulley until I change to the 370's?
Thanks so much for the advise.
Old Sep 28, 2004 | 01:19 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
180K?!?
I'd find 370cc for $250 range or buy some lower mileage stock ones for cheap.
You should AT LEAST get them cleaned/flow tested, you can try this place for cheaper then RC Engineering:
http://www.ptrsds.com/injectservice.html
Old Sep 28, 2004 | 01:46 PM
iansw's Avatar
With a 3.12", I thought people were hitting 11PSI....
Go with 370cc injectors.....may as well get the bigger ones if you're going to spend money on injectors anyway.
A Cartech Adjustable FMU will allow you to tune better than that Vortech will.
Otehrwise, looks like you're in good shape.
Old Sep 28, 2004 | 02:04 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Ummm, dubya tee eff?
WTF are you guys talkin about? I was running the 8:1 FMU disc with my 3.125" pulley on my V1. 6:1 is too lean. I wouldn't go past a 3.33" pulley with the 6:1 disc. I set my base fuel pressure at 36psi.
I also had stock injectors, stock everything internally.
Old Sep 28, 2004 | 02:38 PM
Thanks for all the advise guys. To be honest I dont really have the extra money for the 370's right now. Maybe I should just go with the larger pulley even though I dont want to. And Craig this is your old kit with the same fuel set up you had. You were okay with 10PSI?
Old Sep 28, 2004 | 03:06 PM
Bags's Avatar
How much fuel pressure were you seeing with the 3.125 pulley and 8:1 fmu?
Old Sep 28, 2004 | 05:31 PM
Craig Mack's Avatar
I was fine with 10psi...actually, most of the time I saw 9.5psi by redline. I hit 10psi here and there. I don't understand why people would recommend the 6:1 disc. The kit comes stock with the 6:1 disc to run with the 3.6x pulley, albeit it a little rich it still has no place with a 3.125 pulley. Maybe if you tuned the car on a dyno using an S-AFC and FPR you could get away with it. But a dyno tune would be critical or else you could blow up your motor. Not worth the risk unless you have the tools and proper tune.
Bagzz: Gawd man, its soo hard to remember, it was a while ago....I am pretty positive it was ~83psi by redline. I'm about 95% sure. After I got my S-AFC I remember phucking around with it, and set it at -1 from 1k-5krpm, then richened it +1 from 5-6.5krpm. I didn't have any dyno tunes done or anything as you know, since I dropped that kit for the Eaton Roots setup, and then we all know what happened soon thereafter.
It is my strong opinion that he use the 8:1 disc at LEAST until he gets an FPR/S-AFC to dyno tune with. Without these tools or a dyno tune it would be way too risky and I am willing to bet he will ping near redline every now and then. I'm not sure if Vortech makes a 7:1 disc, but I was contemplating doing that when I had my vortech kit.
Old Sep 28, 2004 | 07:34 PM
Bags's Avatar
With my 8:1 @ 7-8 PSI, I was around 95 PSI. So add another 2 PSI to that and you see why I reccomend the 6:1. I have no REAL answer when our fuel injectors lock up, PSI wise. I stick with the "general consinus" that it's ~110psi. And not to mention the walbro flows crap @100psi.. as seen here
http://forums.maxima.org/showthread.php?t=336440... Thanks for the sticky Stephen
SO now you know my answer for the 6:1.
And yes vortech makes a 7:1 FMU disk
Old Sep 28, 2004 | 10:30 PM
Craig Mack's Avatar
Thank God I don't have to worry anymore about the headache known as boost. All I have to do is sat back and listen to my V8 burble.
Although I dearly miss the attention my crickets and BOV got around town
Old Sep 28, 2004 | 10:33 PM
Bags's Avatar
Put a turbo on the stang.. there are ~10 or so here that make 500+ whp
Old Sep 29, 2004 | 03:36 PM
Craig Mack's Avatar
Turbo Cobras make massive power, but its by far the most expensive route. I was about to pick up a Vortech V1 supercharger used with 20k miles on it, with extras like a 93mm pro-maf, cai, etc. with all the normal hardware like injectors, etc. for $1200! But the guys wife didn't let him sell it, otherwise i'd be making around 500rwhp intercooled @10psi and running 11s.
Oh well....I can deal with the slowbra for now.
Old Sep 29, 2004 | 06:16 PM
Kenneth's Avatar
OG :)
thanks Steve!
Jason - I will send the 3.33 pulley and 6:1 fmu disc out during lunch Friday.
Old Sep 30, 2004 | 09:46 AM
Craig Mack's Avatar
Originally Posted by Kenneth
thanks Steve!
You better not have fouled up my kit b!tch
Old Sep 30, 2004 | 09:55 AM
MaximaRider's Avatar
With the 3.25 on my V2 w/ custom CAI I hit anywhere from 8-10psi, also using the 8:1 disc, Im running rich as hell because I'm not tuned yet, but I rather be rich then blown, oh wait... ;-)
Old Sep 30, 2004 | 11:00 AM
How much boost is the 3.33? Do they make a 3.25 for the V1? Maxima rider are you on stock injectors? how much fuel pressure do you see under boost?
Thanks so much everyone.
Old Sep 30, 2004 | 07:36 PM
Craig Mack's Avatar
Right on Frenchie
Old Oct 1, 2004 | 07:43 AM
Right on Frenchie
Holla G!
I forgot to mention I'm also running the t-rex pump and the walbro just incase. FP is 90+ under full boost?(concentrate more on the road then the gauge with im WOT ;-P), I idle around 38-40~?
Old Oct 1, 2004 | 08:36 AM
Holla G!
Belt and suspenders. A little redundancy in the fuel supply system is probably a good thing.
dank4us
34
Jun 10, 2024 03:45 AM
doombot
Aug 24, 2015 08:43 PM
doctorpullit
Aug 20, 2015 05:15 PM
MikesChevelle
Aug 9, 2015 11:50 AM
