740s are in
Old Sep 27, 2004 | 10:00 AM
MardiGrasMax's Avatar
740s are in
She was flooded very bad afer the swap. I had to put a torch to the plugs to clean them and burn all the fuel off. I let the cylinders sit open for a few hours to air our. She then cranked right up, 0.69 correcfion factor in the e-manage 516cc to 740cc. Idles at 14.7:1afr and revs fine, will test drive her soon. At an actual 5.00v on the Z32 MAF the ECU will only see 3.45v, so I should get some ignition timing advance back as a bonus!
Old Sep 27, 2004 | 10:33 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
pretty good that Emanage can idle them and it should be interesting to see how the Emanage handles it when driving.
Old Sep 27, 2004 | 10:43 AM
Bags's Avatar
VG Ridah's Biatch Hoe
wow.. man your taking it to the complete max here.. Good luck
Old Sep 27, 2004 | 11:06 AM
[maxi-overdose]'s Avatar
mardi: just wondering, are you using nismo injectors?
Old Sep 27, 2004 | 11:12 AM
SonicDust187's Avatar
I am wondering, I know that you are using the JWT program to run the 516cc injectors. Thus using feature on e-manage that correct for bigger injectors, 516-740 to correct. But can e-manage correct if going from 240cc to 740cc with stock ecu?
Old Sep 27, 2004 | 12:33 PM
Yes Nismo 740cc
I can give it a try in a bit
Old Sep 27, 2004 | 02:35 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Please do, however after what you said JWT had to do to fix that cold start issue, I'd say the eManage can't by just shortening IPW anymore.
Old Sep 27, 2004 | 02:50 PM
Another question. If JWT was able to fix the problem with 516cc injectors. Why couldnt htey just do the 740cc program for you? What is your base fuel pressure with the 740cc?
Old Sep 27, 2004 | 02:55 PM
IceY2K1's Avatar
Can you explain that more please?
Old Sep 27, 2004 | 05:50 PM
They have not done a 740cc program so it would take a long time for them to do the 740cc. The injectors will far outflow the Z32 MAF so I will also need the Ford Lightning MAF. They have only done this set up on Skylines.
Fuel pressure is stock 38psi at idle with vac line atached, 43psi with vac line pulled/
Old Sep 27, 2004 | 05:54 PM
The ECU is designed to pull timing as boost pressure (read as MAF voltage by the ECU) increases. If the ECU thinks that I am only at 3.6v (perhaps 8psi) it will give me the timing for its 8psi program, this will obviously have less timing advance than if it were reading my true 5v rading at 15 psi of boost.
Old Sep 27, 2004 | 08:59 PM
Nealoc187's Avatar
SLOW
If (or when) you go with the Lightning MAF, what TB will you use? Q45? Also, what TB are you using now.
Old Sep 28, 2004 | 05:31 AM
I have the 3.5L Pathfinder, I will keep that.
Old Sep 28, 2004 | 08:55 AM
IceY2K1's Avatar
Okay...thanks~!
Old Sep 30, 2004 | 12:04 PM
turbo97SE's Avatar
Congratulations Matt! I was wondering if you have done anything to the fuel rail?
Old Sep 30, 2004 | 12:14 PM
IceY2K1's Avatar
Did you try cold starting with the stock ECU and eManage yet?
Old Sep 30, 2004 | 01:22 PM
Nigel,
I have been considering a duel feed set up, instead of the loop through. I dont think its necessary just yet. with the built 3.5L (somday ) it will be. Just split the feed line into both rails and return them itno my dual port requlator I already have with just one port in use.
Ice,
Not yet, it will be a while, work has been hell latley.
Old Sep 30, 2004 | 04:17 PM
turbo97SE's Avatar
Smart move! I thought of doing that exact thing myself,but I am not even close to outflowing fuel rail yet.
Nigel,
2k0to2k3
Mar 20, 2013 09:41 PM
ImportCarPartsP
Jul 21, 2008 08:29 AM
Shoopdog29
52
Sep 25, 2001 09:24 AM
PhatGuy
Apr 19, 2001 09:19 AM
