Tach Stopped Workin
Old Oct 4, 2004 | 06:55 PM
matty's Avatar
Tach Stopped Workin
Well after my blower install I cant even drive my car
All day my tach had been sticking at 2000 rpms but it would still advance after alittle hesitation past 2k...
Right now It just stopped working..it goes all the way to 2000-2200 but doesnt advance any more.
What could this be ?? the cars running fine and going up in the RPM's fine just not on the gauge ?? anyone know the workings of the tach and if I need the entire cluster or reapair...cluster is 100$ and repair would prob be alot...maybe somethign is loose..anyone know
-matt
Old Oct 4, 2004 | 11:19 PM
matty's Avatar
Anyone ?? I know the Supercharge/Turbo guys know the most on this board and prob have some experience with this...Do I bother 1) taking off the cluster looking for a lose plug/wire or 2) order a cluster from a junk yard and match up Milage somehow? or 3) see if nissan sells Just the Tach and order it from them if i get lucky and its not ONE UNIT ??
-matt
Old Oct 5, 2004 | 12:06 AM
crewchief264's Avatar
Matty:
been reading posts of yours for ever!!! but never replied. Anyways I did th eold cheston and pulledmy needles for the reverse infiglo look for needles and maybe your needles have maybe just jammed upped....very unlikely but, first I would do some ohm(ing)/ volt checking of the sending wire vs manual. If I were you I'd search ebay/local junk yards and find a new cluster and try that last.
Old Oct 5, 2004 | 03:58 AM
matty's Avatar
Well if its jammed can it be fixed or it needs replacing. ?? RIght now im just tryin to figure out where I am, repair, replace
-matt
Old Oct 6, 2004 | 05:42 AM
Confused's Avatar
Permanent Maxima.org Resident
one thing to check before ripping the old tach out is if you have any rpm based accessories running off the ecu tach wire (ie. rpm switch for mevi)
try undoing it and see if the tach works.
Old Oct 6, 2004 | 09:36 AM
matty's Avatar
I dont have anything running off of the tach...
So i guess i have to buy a cluster now
-matt
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
BobTX10
Oct 7, 2015 08:43 AM
maxima297
Sep 30, 2015 03:32 PM
foodmanry
Sep 24, 2015 12:02 PM
