PLMS datalogging
Old Oct 6, 2004 | 10:41 PM
superdave2
PLMS datalogging
Have any of you guys looked at this system? I have it and really like it. It works through the consult port. You can basically monitor and log whatever info your ECU sees. It is very nice for FI cause you can see your total timing. In addition, you can perform the Nissan active tests, check ECU codes, and reset the ECU.
It is cheap too ~$150 usd iirc.
Checkout PLMSdevelopments.com
Old Oct 6, 2004 | 11:37 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
I believe all of us are OBD-II, but maybe 95ers aren't and could use it.
If they come out with the OBD-II version, let me know.
Old Oct 7, 2004 | 07:37 AM
superdave2
You guys and your fancy new cars LOL
This isn't an OBD scanner, it's a Nissan specific consult interface. OBDII cars do not have a consult port?
Old Oct 7, 2004 | 09:55 AM
IceY2K1's Avatar
They do, but it's Consult II vs. Consult I. Protocol is different.
TechnoSquare/Techtom have had something similar called the MDM-100 for displaying a few engine parameters through the Consult I port. They have something now for the Consult II, but it's CAN bus specific I think and that only comes on 2K2+ Maximas. I'm in the no mans' land, ie '96-2001.
Old Oct 7, 2004 | 11:06 AM
superdave2
I sent PLMS an email about OBDII compatibility. Their website does not say anything about OBD compatibility which leads me to think it works with both. But then again they are in Australia so who knows.
Old Oct 7, 2004 | 11:29 AM
IceY2K1's Avatar
They mention only Consult I and then ask for help on locating Consult II protocol technical descriptions and electrical signaling.
The two Consult ports are configured differently, ie number of pins and what they do.
Old Oct 7, 2004 | 03:13 PM
Jeff92se's Avatar
I'm needing a caw
If you are OBDII, why not just use the one of the many OBDII scanners like the Auterra unit for pc/palm?
Old Oct 7, 2004 | 03:27 PM
IceY2K1's Avatar
Consult will have access to non-OBD mandated parameters such as injector pulse width, knock count, etc. depending on the ECU. Plus, if these guys do what they say, you could have preset warnings if something is exceeded and lots of other stuff the Consult-II can see that scan tools can't.
Auterra is more then enough for most probably. There is just a lot more that could be visible, but is it really useful daily? Probably not.
whatsthegoodwor
Dec 26, 2008 01:03 AM
whatsthegoodwor
Apr 13, 2008 05:10 PM
The Law
Jul 6, 2007 12:53 PM
Nealoc187
Apr 24, 2005 12:13 PM
Sin
Jul 11, 2002 04:37 PM
