97 J30 Maf
Old Oct 26, 2004 | 08:49 AM
emeraldmax's Avatar
97 J30 Maf
I just purchased a 97 J30 MAF, but the part # is different.
part # 22680 3lUOO
I'm getting my ECU reprogrammed by JWT for a z32 MAF, will this still work?
Any help would be greatly appreciated, thanx.
Sam
Old Oct 26, 2004 | 11:01 AM
Stephen Max's Avatar
part # 22680 3lUOO
Sam
If it's from a J30, then it will work.
Old Oct 26, 2004 | 11:23 AM
emeraldmax's Avatar
I spoke to someone at JWT just a little while ago, unfortunately, it seems that it will not work. He said it has to have the #3OPOO.... Hopefully they will let me switch this one out, thanks for the reply.
Sam
Old Oct 26, 2004 | 11:31 AM
Sam
You probably spoke to Ben. As usual, he is misinformed. It is a well known fact among Z32 and 240sx circles that the J30 maf sensor is the same as the Z32's. I have one, and the resistance measurements for the hot wire filament and the heater element are identical to my Z32 maf.
Old Oct 26, 2004 | 11:48 AM
Nealoc187's Avatar
SLOW
Agreed... Don't listen to Ben. Like stephen said, it's well known around nissan circles that J30 MAFs are interchangeable with z32 MAFs. The thing you will learn if you deal with JWT enough is that it is a very poor idea to call them up and ASK them questions. You need to call them up and tell them EXACTLY what you want and just have them do it. If you ask them questions they will give you misinformation, tell you certain things won't work, give you the runaround, etc.
Old Oct 26, 2004 | 12:22 PM
emeraldmax's Avatar
Cool, i'll try it out and let u know how it works out. Thanks for all the replies.
Old Oct 27, 2004 | 11:13 PM
subs1000w's Avatar
accually the guy at jwt is right
only 91-95 j30 mafs are the same as 300z mafs
go to car-part.com and do a search on 97 j30 air flow meter
you will find that 96-97 j30s use the same maf as all stock 4thgens and 97-01 q45s
Old Oct 28, 2004 | 05:32 AM
Without verifying that, I'll take your word for it and I stand corrected. Thanks for the useful information.
TallTom
57
Oct 14, 2025 05:16 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 10, 2015 09:35 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
