Broken belt
Old Nov 29, 2004 | 10:06 AM
ExoticCreations's Avatar
Broken belt
Last night the belt on my brothers supercharger broke. It was the stock pulley and belt. And he has had it for like 6 weeks. What is the common problem for the belts to brake.
Old Nov 29, 2004 | 10:25 AM
Stephen Max's Avatar
Pulley misalignment is the most common reason for broken belts.
A slipping belt might also break prematurely due to heat and abrasion.
Old Nov 29, 2004 | 03:12 PM
Max97Stick
my supercharger belt also broke yesterday i was driving in 2nd gear car bogged out i punched it next thing i c all my lights go on rpms drop i pull over belt got shredded
Old Nov 29, 2004 | 04:23 PM
that so sucks, any idea's what happened to you ?
Old Nov 29, 2004 | 04:42 PM
matty's Avatar
Within 6weeks it sounds like a misalignment problem...you need to find your problem and shim out the blower or shim one of the other pulleys or even your main pulley on your blower slightly towards your engine, to align everything...it will be a shoot and miss kind of thing till you finally find what lines everything up...
-matt
Old Nov 29, 2004 | 05:10 PM
vortechpower's Avatar
Do you guys look under the hood much? I have never had a belt just randomly break with no signs. Maybe your belt was loose and it hopped a rib on the sc pulley and you continued driving until it shreaded. Your sc will still work while belt has jumped a rib. I dont beleve in belts just suddenly breaking theory with no warning
Old Nov 29, 2004 | 05:11 PM
-matt
If you can drive for 6 weeks the alignment cant be that off if any.
Old Nov 29, 2004 | 05:30 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
how did you intall the idler pulley?
does it look even with everything else?
which way did you screw in the alternator?
how much out of alignment is the s/c pulley?
Old Nov 29, 2004 | 05:38 PM
Max97Stick
i think thats what happened to my belt it got shreded it came of the charger , it has 2 ribs left on the belt so i just cut it off
Old Nov 29, 2004 | 06:10 PM
Nismotech1's Avatar
confident nissan owner
ok what happened is i let my brother drive my car, he took it on a road trip blasting the radio i'm sure and i'm sure he was driving it hard, i think the came loose theary makes sense, i about 3 weeks ago checked the belt and had to tighten it, so it is possible that it jumped and broke, my brother told me he saw the belt next to the pulley what was left of it but he kept driving, i could kill
Old Nov 29, 2004 | 06:11 PM
Nismotech1's Avatar
i never unscrewed the alt. on 2k1 it says nothing about this in the directions, and the belt looked new still when i tightened 3 weeks ago
Old Nov 29, 2004 | 06:20 PM
Nismotech1's Avatar
i have a dumb quick question....
since we have the same compressor as a mustang ca we buy the mustang pulley?
i want to buy the 2.87 pulley since i have to take it apart anyway. 6 rib right?
Old Nov 29, 2004 | 06:29 PM
I hardly ever drive with radio on in stop and go traffic. I have made the belt jump a rib by spinning wheels to much. 2.87/ 6 rib, thats right. $75 from vortech and about 5 business days. I down shift once from 5th to 4th (trying to slow down real fast) going 135mph, it jerked the belt so hard it started shreading instantly. That was such a dumb thing to do, rpm's went straight to redline. Try and get your self in the habit of looking under the hood atleast once a day to make sure the belt is on right. Just a quick peak can only do you good.
Old Nov 29, 2004 | 06:58 PM
Nismotech1's Avatar
thanks for all your help i do apreciate it, you guys are great
Old Nov 29, 2004 | 06:59 PM
Nismotech1's Avatar
another question. this one's for the belt.
do they make a high performance belt? or is gates as good as it gets?
Old Nov 29, 2004 | 07:22 PM
matty's Avatar
Goodyear Gatorback is a good belt...thats the one im using
-matt
Old Nov 29, 2004 | 07:48 PM
Max97Stick
anybody know the part numbers for the goodyear gatorback
Old Nov 29, 2004 | 08:35 PM
no I dont. I do know alot of people have a hard time finding the gatorback. I have always used the gates just because I dont take the time to find them either. Someone will soon drop the belt size for you.
Old Nov 29, 2004 | 08:47 PM
matty's Avatar
695 - 3.125
690 - 2.87
Go to your local Goodyear Tire place
-matt
Old Nov 30, 2004 | 04:30 AM
If I'm not mistaken, Mustangs have an 8 rib crank pulley, so their SC pullies also have to be 8 rib.
Old Nov 30, 2004 | 05:52 AM
meccanoble's Avatar
Sports Button FTW
its all about proper installation. I had my supercharger for 4 months, never had a problem with belts.
Old Nov 30, 2004 | 08:12 AM
BlackCat's Avatar
RIP '98 Maxima SE
I've noticed that the belt would jump if the engine hasn't warmed up enough, even with my washer shims in place. This happened once to me even during the hot summer. Best to drive around normally for a while to get the belt and engine up to normal operating temps before laying on the pedal.
Old Nov 30, 2004 | 04:59 PM
Nismotech1's Avatar
ok today i got a break down of what the belt #'s mean for instance the gates belt
k060703
06=6 ribs and
0703=70.3 inches i think thats alot easiar way of understanding your belt size, now i a gator back you all rec, a 690 which would be 69 inches, from what i understand that would be 1.3 inches smaller than a gates belt. er aybe thats why the gatorback is better because it fits tighter... so with this theary i assume the proper gates belt for a 2.87 pulley would be a K060690. does that sound right?
-jeff
Old Nov 30, 2004 | 07:27 PM
matty's Avatar
695 - 3.125
690 - 2.87
-matt
690 = 2.87" pulley
695 = 3.125 Pulley
-matt
Old Dec 2, 2004 | 09:00 AM
Max97Stick
i just got my belt fixed i had alil branch got caught and shreded the belt
Old Dec 2, 2004 | 09:36 AM
BlackCat's Avatar
RIP '98 Maxima SE
How the heck did a lil branch get up in there? Did a squirrel make a nest in there?
Old Dec 2, 2004 | 10:59 AM
Max97Stick
i duno bro but its been madd windy the last few days and floods all over
Old Dec 2, 2004 | 12:32 PM
damn lil branch
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
markevans999
Oct 25, 2015 08:27 AM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
