Read through stickies and some ?'s
Old Dec 9, 2004 | 12:22 AM
Oblongshapes's Avatar
Ok, for the 370 95-96 300ZXTT cc/min injectors with a rounded olive top some people said that they were plug and play into the maximas fuel rail and electrical connectors? Then someone else said they had to get different connectors..... Which is it?
I believe the part # on these were 16600-21u01
To put in a j30 or z32 MAF sensor, must you have the ECU reprogrammed in order for it to function properly? Or Can the Emanage take care of that too? I like how you can change the Emanage as you keep modding, whereas the ECU is permanent unless you want to keep paying for it to be reflashed...
Does anyone have those Cattman Cams...
Are they supposed to reduce valve overlap, since we do not want it or very little for FI applications?
What time of air filter are you guys running?
Old Dec 9, 2004 | 09:34 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
if you put the z32 maf and injectors with the a32 ecu, the car will function normally.
the cattman cams are more for use with na due to the overlap (fi you do not want that)
I forget which air filter, it wasnt in the stickies? check for the cai setup. if not, i'm sure that one of the hks style monster filters will work.
steve
how bout them stillers.
If you are planning on going fi, i should be back out to oakland to visit in march.
Old Dec 9, 2004 | 11:58 AM
Bags's Avatar
VG Ridah's Biatch Hoe
The 1995+ nissan 300zTT injectors will plug directly into the 1995+ nissan maxima injector harness
No, but you will need so sort iof tuning device such as the Emanage or SAFC
Type????
Depends on your application.. K&N cone for me
Old Dec 9, 2004 | 12:52 PM
iansw's Avatar
I had the stock ECU running the Z32 MAF and 370cc's when I went to pass emmissions. <SC was unhooked>
It works fine down low, but at high RPM the car would stutter and buck.
Stephen Max had the same thing happen.
So the answer is - yes - it will work at low-mid high RPM - just don't run it like that permanantly and don't go to high RPM.
IanS
Old Dec 9, 2004 | 01:11 PM
slimer's Avatar
would wbo2 tuning help the buck? i assume its from being too lean.
Old Dec 9, 2004 | 01:24 PM
iansw's Avatar
Not sure........
Old Dec 9, 2004 | 02:37 PM
Bags's Avatar
I don't see why not
mclasser
22
Nov 12, 2020 01:58 PM
chisam14
Nov 6, 2018 08:56 PM
mkaresh
Mar 12, 2018 06:48 PM
maxinout93
Oct 31, 2015 02:04 AM
