Got my pipes back
Old Jan 30, 2005 | 08:26 AM
  #41
slimer's Avatar
A couple of Blaxxx's? Lawls.
mike-i am dropping my stuff by on monday or tuesday.
He quoted my $70 for everything.
I hope that I can reinstall everything next weekend.
btw-he said that he could do ceramic coating for around $150 for our shorty headers and y-pipe.
Old Jan 30, 2005 | 02:12 PM
  #42
I30tMikeD's Avatar
I don't know about you, but my headers are never comming off again. Once was enough for me
Old Jan 30, 2005 | 02:19 PM
  #43
stephenlc's Avatar
the front is easy, the back header sucks.
Old Jan 30, 2005 | 02:45 PM
  #44
slimer's Avatar
the egr was the worst part for us.
dave and his ogre hands!
Old Jan 30, 2005 | 04:26 PM
  #45
stephenlc's Avatar
i havnt done the back header yet. Sorry off topic, but I was wondering how you take the egr tube outta the header?
Old Jan 30, 2005 | 06:44 PM
  #46
Broaner's Avatar
2060lbs and falling...
I used a big @ss channel lock to get the EGR tube off. I didn't have the firewall to deal with though.
Old Jan 30, 2005 | 08:36 PM
  #47
stephenlc's Avatar
it roates right, like a bolt?
Old Jan 30, 2005 | 09:02 PM
  #48
slimer's Avatar
yeah, its a pita
Old Jan 31, 2005 | 09:51 AM
  #49
Broaner's Avatar
Yeah. It has a collar with the threading on it. Its a flange fitting kinda like brake lines except an @ss load bigger.
Old Jan 31, 2005 | 10:20 AM
  #50
iansw's Avatar
It costs me $95.00 to get this ceramic coated in Seattle at Performance Coatings in Auburn, WA
http://www.performancecoatings.com/ <-----Link.....
Old Jan 31, 2005 | 10:58 AM
  #51
stephenlc's Avatar
why did you get itake piping ceramic coating. Does it keep the air inside cooler than the temp of the engine bay?
Old Jan 31, 2005 | 11:00 AM
  #52
iansw's Avatar
Yep.....Just like heat wrap - but much better looking.
In honesty, however, the temp difference is probably minimal - mostly it just looks sweet.
But then again - every tiny bit helps.
Old Jan 31, 2005 | 01:07 PM
  #53
Broaner's Avatar
I also wondered about ceramic coating the charge pipe. True, it is sitting behind the radiator and above the exhaust manifold but it is getting a bunch of cool air from around the radiator. Ian, did you happen to log before and after IAT temps? It could be a double edged sword. You could be stopping it from soaking in heat but you could also be holding it in at peak boost. What charge temps are you reading with your current boost level? I think we should compare that to others. Anybody else have logged charged temps to compare? The ambient temp doesn't really matter. I'm just looking for a ballpark. The radiator puts out no more that 200 degree air so the only way it would be gaining heat is if the exhaust was much hotter than what I'm guessing.
Old Jan 31, 2005 | 01:24 PM
  #54
iansw's Avatar
I never did any temp readings - but I can say that I used to notice power loss from heat soak on hot summer days and now I don't so much.
Old Jan 31, 2005 | 01:55 PM
  #55
slimer's Avatar
Stephen max has thermocouples everywhere. He monitors the effect of one mod versus another. he noticed that re routing the piping in front of the radiator dropped his iat a lot.
i was thinking about getting the aftercooler ceramic coated, but the guy didnt have anything that would look like Ian's chrome.
I guess i like a little show and a little go.
Old Jan 31, 2005 | 08:21 PM
  #56
Broaner's Avatar
Thats good info Ian but how did you notice a difference on hot summer days if you just had this done? It is January.
Steve, a little go? Ha. I knew Stephen had done Iat testing but I didn't know he did that before the intercooler. I'll send him a PM to ask him for his opinion.
Old Jan 31, 2005 | 08:22 PM
  #57
iansw's Avatar
I had it done last June.
Old Jan 31, 2005 | 08:24 PM
  #58
Broaner's Avatar
My bad. Then its very good info. This is why you gotta get your homepage updated. Where do you host your pics? I'd like to look through your collection.
Old Feb 1, 2005 | 05:26 AM
  #59
Stephen Max's Avatar
Yes, that's right. I saw a 25-30 deg F temperature drop after routing the intake around the front of the car and away from that Devil's triangle of engine, exhaust manifold and radiator. It totally eliminated some pinging I was getting during partial throttle acceleration, and only dropped the boost pressure by about .2 psi. It's not an easy mod, though.
Old Feb 1, 2005 | 07:10 AM
  #60
slimer's Avatar
yeah, i looked at the install pics. so help out that problem im thinking of getting that front bank ceramic coated to reduce the heat that comes from there.
the rear bank is so much of a pita to get to
JRod28
Dec 29, 2023 09:56 PM
Stagnet04
Sep 2, 2015 07:53 AM
stromm
Aug 27, 2015 04:13 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
