What Idle problems/emanage?
Old Feb 2, 2005 | 03:26 PM
crewchief264's Avatar
I will be running a 2.87 or 2.62 pulley with injector/ignition harness and psi sensor for boosting when I max out stock maf, and using emanage to tune the 500-550cc for everything from idle to max throttle/boost with no fmu.
I don't understand why shadow is having to tune with a sard and why he doesn't just use emanage? Also I am under the impression that the set up i plan to use above will require no fmu etc, it will all be taken care of by emanage.
Old Feb 2, 2005 | 03:41 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
You'll still want the Z32 MAF....the MAP sensor is for tuning beyond the MAF capabilities and not for when you exceed the stock A32 MAF off the dyno.
Sorry, but OT.
Old Feb 3, 2005 | 01:29 PM
Shadow's Avatar
I'm not tuning with the SARD. I'm trying to drop the idle fuel pressure so the car will start and idle correctly. On startup, the car is running off of a preset program and the emanage can't do anything.
Old Feb 8, 2005 | 01:51 PM
Sorry, but OT.
i don't agree that I'll need an z32 maf. I will not be maxing the voltage on the a32 until close to redline, so that is where the emanage psi sensor comes in. When I'm dyno tuning the car with the emanange we can opt to use the psi sensor inputs rather than that of the maf since it will be maxed out or close to it! Please correct me if you think this wrong?
Old Feb 8, 2005 | 02:28 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
i concur...........
Old Feb 8, 2005 | 03:36 PM
IceY2K1's Avatar
Per eManage SM "duty cycle of the injector cannot exceed 100%", so at 100% MAF capacity, you are at 100% duty cycle and the injector harness can't add more via the Additional Injection Setting map.
Even if you could increase fuel via the injector duty cycle, once you exceed the MAF, you are no longer an airflow referenced system and any changes after you dyno tune via the MAP sensor will affect the AFR like temperature/humidity.
For $50 or whatever for a Z32, you'd be . Just my .02.
Originally Posted by seximagtr
i concur...........
Old Feb 8, 2005 | 03:46 PM
Blu's Avatar
Blu
the tits
What kind of power do you expect to be making? I dont see why you need 550's if you aren't going to be making enough power to max out the A32 MAF. That is unless you plan to jack up the FP via a FPR and lean out the low end using emanage.
Old Feb 8, 2005 | 03:53 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Old Feb 8, 2005 | 03:58 PM
Shadow's Avatar
It's the same money for a Z32 MAF. Just buy a J30 one, same thing and it's $40-$80 on eBay. Isn't the MAP sensor more than that? I was going to go the MAP route until I found out about the whole lack of airflow measurement. You really shouldn't be using a static measurement taken from one dyno tune to control your fuel management on the street.
And the others are right, why 550's if you're only maxing out an A32 MAF at redline? At 7psi, I maxed mine out ~4700 rpm based on the emanage log, it hit 4.9V there.
On a related note, Z MAF went in today, 660's will be here next week and then we'll find out how much power 12psi will put down.
Old Feb 8, 2005 | 04:20 PM
i am expecting between 300-350 at the wheels. so I think I will be at the verge for the a32.
Also i don't think I can run a z32 maf with my stock ecu can I. thats why I went with emanage! i don't want jwt to throw codes and it just isn't tunable enough for me, and the turn around time.
Old Feb 8, 2005 | 04:38 PM
DA-MAX's Avatar
Emanage will throw 1 or 2 codes and CELs too(at least on the 99) that you can't avoid
Old Feb 8, 2005 | 04:39 PM
Blu's Avatar
Blu
the tits
Im pretty sure the Z32 MAF will work with a none JWT equiped car. I believe someone did it recently but I can't remember who it was.
Old Feb 8, 2005 | 04:46 PM
DA-MAX's Avatar
I think Stephen did it a long time ago with the AFC and some tweaking, but never got it fully functioning to the point it was reliable.
stock ECU + emanage and you can run the Z32 MAF fine...I'm convinced it makes sooooo much of a difference after seeing that 3.7v at 10psi @ WOT...you can't beat that
Old Feb 8, 2005 | 08:53 PM
MAXimumHP's Avatar
Like what out of curiosity since I will be wiring one up soon?
Old Feb 8, 2005 | 09:18 PM
DA-MAX's Avatar
I can't remember off hand, cause I haven't had to identify them since I installed Redmax's Emanage last spring...we just ignore the CEL. I know for sure one is ignition related. once you install the ignition harness it pops up, and as far as I know there is no way around it. mind you these CELs will not affect performance(to our knowledge at least), its just that the ECU detects something foreign and/or a secondary device altering the signal and throws a code.
Old Feb 8, 2005 | 09:23 PM
MAXimumHP's Avatar
Ok Thanks, I'm not installing the ignition harness initially. BTW, do you know the correct jumper settings when using the ignition settings.
Sorry about the OT, this is my last question.
Old Feb 8, 2005 | 11:42 PM
pawnstar12's Avatar
BUY MY CARS PLEASE!!!
i have a z32 and i used it w/ a afc2 with no problems at all. you just have to run richer than stock
Old Feb 9, 2005 | 06:19 AM
So the concensus is that the z32 maf won't work with the stock 97 ecu, even with ecu.
Please correct this if it is wrong? a32 maf, 550, psi sensor (for correcting where the maf might cut out and using emanage to tune off psi, which would understandably not be as efficient as the maf, but cost wise work well enough) and the ignition/injector harness.
By the way I am expecting to only see 10psi with the 2.87 since I am intercooled.
Old Feb 9, 2005 | 06:22 AM
Shadow's Avatar
No, the Z MAF will work with the stock ECU if you have the emanage or AFC.
Old Feb 9, 2005 | 06:26 AM
How do you have to wire it (z32) up to the car/stock 97 ecu and what do you change in the emanage when you do this so there are no codes and problems, please be detailed and give why's?
Old Feb 9, 2005 | 08:17 AM
IceY2K1's Avatar
Dude, you need to READ. Do you see the sticky's at the top?
http://forums.maxima.org/showthread.php?t=328401
All your answers are here, you don't listen nor read too well.
eManage settings have been posted several times, recently even.
Old Feb 9, 2005 | 10:04 PM
pawnstar12's Avatar
what ever you do not wire it backwards, like i did. you will blow the maf
Old Feb 10, 2005 | 07:19 AM
I was finnally able to find the z32 thread I was looking for. And the psi sensor for the emanage makes since for not having the ability to tune like the maf.
I am going to be working with a guy in michigan to tune this emanage, and I don't wanna trailer my car all the way there and then run into something where it needs more parts and what not.
So if I go with the z32 maf there should be no need for the psi sensor?
And will the z32 maf plug and play as far wiring goes?
Also once the z32 is in, is the adjustment made via the emanage software or the ***** on the emanage?
Please IceY2K1 before you, call me an Idiot, I have reached the treshold of my knowledge (I have a lot to learn about emanage) and am trying to learn as much as I can about the emanage so I have a good idea how the tuning, wiring, and install in Michigan goes and so that I don't up there without things I need and so I'll have the answers to "How'd you plan on this working" questions?
And yes I have read them and there are a lot of general things in the stickies that I don't think apply to my specific set-up. I prefer the direct input of people who have ran a setup like I am planning to go to.
Old Feb 10, 2005 | 07:52 AM
IceY2K1's Avatar
If you expect to make near 290whp, get the Z32/J30 MAF.
So, you are planning on driving the car to Michigan once you've installed the Z32 MAF, but not the eManage?
Not unless you go over 350whp, which I doubt, however the PSI sensor is a good option to have for logging boost and if you get the Greddy Pressure Gauge(~$180), you can use its sensor as an input to the eManage.
No, it's not plug-n-play. You have to cut off the A32 MAF electrical plug and splice on the new Z32/J30 MAF plug. Read the threads in the sticky for how the wires are hooked up.
Both. You need to set the ***** on the eManage and then you MUST use the support tool software to set up the other parameters according to the manuals I posted.
I never said that. You just don't seem to listen to the OTHERS here who have done this before and know what they are doing. You NEED to listen to them and how they've set this up or you'll go through the SAME learning pains they all did.
Reread about how to wire the Z32 MAF, because you'd know it's NOT plug-n-play, ie requires rewiring the electrical plug.
GOOD LUCK and you'll have a beast once you've successfully tuned the eManage Air Flow correction maps and Ignition Timing maps.
Old Feb 10, 2005 | 04:15 PM
ok I was finally able to read the sticky on the z32 again it's been like year since I read those!
So is there a reason why you shouldn't run the z32 on the psi side?
It is relatively the same as the a32 other than circuitry right?
Old Feb 11, 2005 | 06:00 AM
Shadow's Avatar
I think that you're not supposed to run it on the pressurized side because of potential failure. Same w/ the 5th gen MAF.
I'll find out, I'm running it on the pressurized side, and I believe several people have done it before.
Old Feb 11, 2005 | 08:00 AM
IceY2K1's Avatar
Only reason I can think of is heat generated by the charge air causes the pressurized MAF to read differently and fail sometimes. However, people still do it without issues.
Old Feb 11, 2005 | 02:07 PM
thats good news cause I spent too much time welding up my new intercooler pipes and making flanges to scrap them and move the maf on the other side.
thanx
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
