turbo manifold?
Good luck buying just the manifold, custom fabrication is your best friend
For pics, check http://maxima.dynomagic.com/ - there are lots on there!
Depending on what kind of set-up you want to run there really isn't a turbo manifold. On mine it is basically just a y-pipe that runs off of the stock exhaust manifolds to the turbo. Without buying a kit looks like it is going to have to be a custom job but shouldn't be that hard because there really isn't to much to it. Good luck with your project. What kind of turbo you going to run??
Originally Posted by slimer
nice plug hal, but really check out some of the diagrams on there. they will help you decided what you want to do for turbo
maximagunner, MardiGras posted his PFI feedpipe for sale today, that would be worth checking into! keep in mind it's a PFI pipe though
Originally Posted by maximagunner
yes, i've done alot of research on turboed maximas, i just figured the hardest part will be the exhaust feed pipe. i have a welder and all, i just dont want to make the feed pipe,lol. can someone make one for me?
btw, whats wrong with the pfi pipe?
I don't think they use crush bends anymore. At least the last one I saw wasn't crush bent. The original couple of kits were crush bent though.
Originally Posted by hlh0501
the routing going backwards, then forwards... more lag. also, last I heard they are still using some crush bends? I don't really keep up with them though - maybe they have changed?
litch
123
01-04-2024 07:01 PM
