VQ35 and boost
Old Feb 11, 2005 | 08:28 AM
  #41
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
One guy? Come on Neal, you know how that goes.
What I've seen in many many cases on the my350z.com board is that the guys who spend the time/money doing the tuning are fine and have run 10K-20K without problems at moderate boost. It's the x-Honda pay someone to do the install and get a half azzed tune, that end up blowing their engine. These guys just bolt on a kit and then go run them without even checking AFR or retarding timing, which in the VQ35s is a fatal mistake.
Old Feb 11, 2005 | 08:43 AM
  #42
chris'smax's Avatar
Originally Posted by IceY2K1
Yes, it would drop compression.
The intake ports on the newer VQ35 heads are angled different and require a VQ35 manifold. However, you could use the 2001-2004 Pathfinder VQ35 heads maybe, since they used a similar type port.
You're SC'd, so you don't need/want to drop compression, just buy cams and you're going to flow plenty of air.
As in the 3.5 stock cams or some aftermarket cams?
Old Feb 11, 2005 | 11:25 AM
  #43
IceY2K1's Avatar
Nobody has shown the difference of VQ35 stock cams in a VQ30, so I can't say if it's worth the install or not, but they are cheap around $100-$150.
Anyways, the VQ35 Tomei's would be my pick after Tilley drilled out the hole and I bought JWT spacers.
Old Feb 11, 2005 | 12:01 PM
  #44
Quicksilver's Avatar
OT n00bs FTMFCSL
Pauter rods are overkill...there are better choices for non-turbos.
I've never head someone say that about their rods I think they are beautiful, personally...
Old Feb 11, 2005 | 01:14 PM
  #45
IceY2K1's Avatar
Actually, it was brought up by another rod manufacturer who stated that any additonal weight/material beyond what your intended goals are is eating hp/responsiveness.
Makes sense to me, since those Pauter rods are beefy SOBs intended for serious boosted motors, ie 800-1000hp maybe?
I think Carrillo makes a perfect high rev NA or moderate boost application Pro-A beam rod that would be superior to the OEM VQ35 rods, but not bomb proof like the Pauters.
Old Feb 11, 2005 | 01:49 PM
  #46
OT n00bs FTMFCSL
Actually, Pauter will make you N/A rods as well as the HD boosted application ones. Well, I know they did back in my VW tuning days. I would assume they do the same thing here...
Old Feb 11, 2005 | 02:41 PM
  #47
IceY2K1's Avatar
Cool, didn't know they did also.
I guess my point was that these guys don't need the Pauter turbo beast rods guys are using for 500-1000whp, but whoever makes something slightly stronger then OEM VQ35 rods without going overkill.
Old Feb 11, 2005 | 02:45 PM
  #48
JeffesonM's Avatar
living out of a maxima...
I browse the 350z forums almost as much as I do here and I'd tend to agree with Ice's summary of the crank angle sensor situation... I think it's definitely something that needs to be addressed but with one or two exceptions it's not the cause of blown motors. Detonation is.
Old Feb 11, 2005 | 03:06 PM
  #49
IceY2K1's Avatar
ETA on that monster?!?
What rods are you using?
Originally Posted by MardiGrasMax
My block is ready at the machine shop
Old Feb 11, 2005 | 03:16 PM
  #50
IceY2K1's Avatar
Yeah, Neal, I know Charles/Phunk or at least I've read all his posts over on my350z.com and I've been following his build up and tuning with the HKS FCON Pro.
He is a very capable tuner and is marketing a "Crank Angle/Cam Angle wire fix", so he isn't biased. Just kidding, he also came up with what seems to be the best solution to converting the Z returnless->return style fuel system.
Like I said, I don't doubt it's a problem, just not the witch hunt people are making it out to be and for $154, it's worth the piece of mind.
Old Feb 11, 2005 | 04:54 PM
  #51
MAX2000JP's Avatar
Out of 15-20 blown motors on the 350Z board I read, there are A LOT more, 1-2 are suspect of this issue.
I'd guesstimate this is a 10% or less occurance and people are using it as an escape goat to sell their "solution to the problem". Problem really is that Nissan weakened the internals by reducing weight and when people throw TT kits that produce healthy amounts of torque at low RPM, rods bend/snap. Even Nissan knows the rod bolts can't sustain 7200+rpm, so Nismo sells rod bolts, and even after those they don't specify any higher. Then for the 2005 "300hp" Z and "290hp" G, they redesigned the COMPLETE rotating assembly. So, apparently Nissan has something in mind for the future or the 3rd gen VQ35s were near their limit at 287hp to cause a complete redesign for a minor 13hp increase.
Anyways, the CPS->ECU shielded cable is not just a "simple" black/white here is the answer to your bending rods as you made it sound.
Did you read the link I provided on the first page? The internals are good for 500+ whp when tuned correctly. A local tuner called Genesis Racing recently tuned a APS TT kit to just that. My friend Brian, BriGuyMax on the .org, bought a APS kit and did a ton of research on it. He was told by Charles and others in the 350Z community that this was the cause of a lot of blown engines. APS provides the grounding kit stadard in their kits. You admitted detonation was the cause of many of the blown engines; APS's testing and theory seems to hold very very true when you think about it.
Old Feb 11, 2005 | 04:58 PM
  #52
MAX2000JP's Avatar
Not to be mean, but I don't think you understand the problem at hand. You say detonation is the cause the majority of the time. Please read the APS link it will explain it to you clearly. The interference is causing the timing to be advanced at the wrong time, which causes DETONATION.
Old Feb 11, 2005 | 05:01 PM
  #53
MAX2000JP's Avatar
Any engine from an LS1 to a B16 will fail if you add X amount of boost and don't properly tune it.
Old Feb 11, 2005 | 06:18 PM
  #54
JeffesonM's Avatar
I have read most all of the threads in the FI section over there. I guess I should clarify... it's my belief that most of the blown engines were from detonation due to tuning, not because of the crank angle sensor wire issue. One case I recall where I believe it was the culprit is the guy gurgen over there who had all the bases covered (plenty of fuel, good tuning, J&S, etc) but still blew his motor. I know many early Prochargers bit the dust due to no timing control and I think more than a few of the Greddy TT's fell victim to poor tuning. I agree the crank angle sensor is a definite problem, I just don't think that if everyone knew about it from the start none of their motors would have blown.
Old Feb 12, 2005 | 08:15 PM
  #55
Nealoc187's Avatar
SLOW
Hmm I made a post in this thread yesterday that seems to have disappeared? Weird.
Old Feb 12, 2005 | 08:25 PM
  #56
JClaw's Avatar
Government conspiracy
Old Feb 14, 2005 | 08:54 AM
  #57
IceY2K1's Avatar
Not reliably, but maybe for a limited time. Yes, people here squeeze 450whp or more out of a stock VQ30, doesn't mean it's going to last very long. VQ35 rods have been shown to not handle 450whp even with perfect tuning and no signs of detonation and is considered the "limit" of the stock bottom end with FI.
APS is biased and has been selling this escape goat for months even before they released the info. Charles/Phunk tends to jump on stuff to bring a new product to market.
Again, it's most likely a problem, since Nissan had a recall on the sensors. These guys are just blowing it out of proportion to make money. Don't believe everything APS tries to sell you.
Old Feb 14, 2005 | 09:07 AM
  #58
MAX2000JP's Avatar
Please do a little research on the "limits" before posting. You are making up numbers for the limits of the VQ35 because it isn't really known. Look back a few years ago to Maxima performance and what people were saying. Again, my friend Brian has done a ton of research on this kit including talking to Charles himself. He could have went with a number of kits including the Greddy which Charles sells. APS chose to make a kit that was as close to what a factory kit from Nissan would look like. The "fix" is inlcluded standard in their kit, so I doubt they are making a huge profit off it.
Old Feb 14, 2005 | 09:20 AM
  #59
IceY2K1's Avatar
I've done enough research to know that people who have reliably ran TT kits for 10-20K miles withOUT blowing are saying that is what the limit is. Yes, you can push 500whp or more if tuning is perfect, but it's past the being moderately safe and you'd better be prepared to drop in a new motor.
APS is using their "fix" to market their kit as superior to the Greddy and PE kits, so yes they ARE trying to justify why their kit is better and making a profit.
Old Feb 14, 2005 | 09:31 AM
  #60
MAX2000JP's Avatar
How do they know the limits, if they haven't blow the engine due to pushing the performance envelope? It is all hearsay and estimates. As in any motor, the tuning is key. Look back a couple of years and see what people were saying the limits of the VQ30 were. People like Mardi and Hal proved them wrong. When you modify your car, you are assuming risks and I am sure people pushing 500whp are prepared for the worst.
Old Feb 14, 2005 | 09:53 AM
  #61
IceY2K1's Avatar
Because they're the only ones still running the stock motor at 400+whp, while others have blown, one even twice?
There is ONE 500whp APS TT kit on stock internals, I can see, so time will tell. Even he knows it's a crap shoot, but he is PREPARED to put in a new motor.
Again, words of wisdom from the GUYS RUNNING, is to keep it under 450whp with good tuning and you can expect a decent long life out of the stock bottom end. Start pushing 450whp to 500whp and as long as you have your tuning/fuel system, it will handle it short term. Push over 500whp and you'd better be prepared for built internals.
Mardi/Hal haven't proved anything other then the fact that for the short term, VQ30s can handle 400whp even 500whp for limited bursts. Hal went through several motors to acheive that and Mardi was running SC'd with some N20.
Old Feb 14, 2005 | 10:11 AM
  #62
MAX2000JP's Avatar
Again, this is all based on estimates. No one knows at what point the internals will fail due to too much power. Charles's own 350Z was daily driven for a long time at 450+RWHP while being abused. He took the car to the track quite a bit, street raced it, and had hours on the dyno tuning and tweeking it. He drove the car around as a daily driver, don't know how many miles it lasted, but I can ask Brian.
I would disagree that Mardi/Hal haven't proven anything, but that's another arguement. Look way back 3-4 years ago and see how things have changed regarding the power estimates of our engines N/A and F/I. When I first registered here, modded 4th gens could hardly break mid 14s, now with some development work they can run mid 13s.
Old Feb 14, 2005 | 10:55 AM
  #63
IceY2K1's Avatar
I agree, just estimates, however based on the 15-20 blown engines, that's the trend vs. ONE 500whp car with limited miles/time.
Charles also had issues with that engine at 470whp, loss of compression and power IIRC, AGAIN he ran that power level with the intent of building up his spare motor.
Back to the topic of the thread, 450whp and less has a moderate life expectancy on a VQ35 stock bottom end.
Last, it's NOT just a "simple" buy this CPS wire fix and all you can run 450+whp with decent tuning without blowing as you originally implied.
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
MichMaxFan
Sep 30, 2015 09:18 AM
