Those with pfi kit look here..
#41
![](https://maxima.org/forums/images/smilies/support.gif)
Think I got it!!!
Ok. So I got a T-fitting with 1/8 NTP female's all three ends
![](https://static.summitracing.com/global/images/prod/norm/ear-991701_w_m.jpg)
Then for the sender side of the T-fitting I will use a 1/8 NTP male to a 1/8 BSPT female. The 1/8 NPT/BSPT adapters can be found at www.splparts.com
![](https://www.splparts.com/Parts/Universal/Hardware/Fittings/NPT2BSPT2.jpg)
For the block side I will use a double sided 1/8 NPT male to go into the female end of the T-fitting
![](https://static.summitracing.com/global/images/prod/small/ear-991103_s.jpg)
Then a 1/8 NPT female to a 1/8 BSPT male adapter to go into the block
For the feed pipe I will just use a 1/8 NTP male to whatever AN fitting I have (don't know what size it is yet)
In addition. I think using the two adapters on the block side of the T-fitting will also give me enough clearance past the oil pan.
04-16-2020 05:15 AM
Kyle Lee Cleveland
09-28-2015 07:58 AM
Pied
09-26-2015 03:29 PM
