Zeitronix Wideband reviews
Old Feb 16, 2005 | 03:25 PM
  #41
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
WTF? Your RPM seem to be off? Where are you tapping your RPM signal?
Guessing at the RPM vs. TPS vs. AFR, looks like you hold ~13:1 AFR pretty well.
If you can get a log of just a 3rd gear WOT 60mph to redline run, that would be easier for at least myself to visualize.
Old Feb 16, 2005 | 03:44 PM
  #42
SR20DEN's Avatar
VQ Wizard
Originally Posted by SR20DEN
Be sure to setup the software for 6 cylinders and omit the boost, EGT and user data when studying my log file.
Old Feb 16, 2005 | 03:59 PM
  #43
IceY2K1's Avatar
That looks better.
Old Feb 16, 2005 | 04:34 PM
  #44
SR20DEN's Avatar
VQ Wizard
Originally Posted by IceY2K1
That looks better.
10k rpm does look cool though.
Old Feb 16, 2005 | 04:51 PM
  #45
BlackBIRDVQ's Avatar
drag racing is for wussies
PLX M300 here and the response time is just as good as the Horribra wideband 02 sensor my local ricer shop has on their DynoJet. Have not used it on the Max yet as I haven't gotten around to welding on a bung in my HS ypipe to see what the A/F is. Tunned my G20 with the M300 without dataloggin on the street with my brother driving and me adjusting the A/F on the laptop via Emanage, works great for the 300 bux I paid for it, and I have 5 spare brand new Bosch oxygen sensors for it through my source at VW
Old Feb 16, 2005 | 04:57 PM
  #46
SR20DEN's Avatar
VQ Wizard
I am talking about LCD response time. Not the data rate which is 30 frames per second.
Old Feb 16, 2005 | 07:22 PM
  #47
superdave2
I had problems with LCD response times when cold too. But as soon as the car warmed up a little, it was fine. I would also get an artificially high EGT reading when the unit was cold.
I still love it though... but that new PLx system looks beautiful!
Old Feb 16, 2005 | 07:50 PM
  #48
nateplaysbass's Avatar
Originally Posted by superdave2
Icey2k1 is right...
a narrow band is on only a 1v sensor, not 5v. 450mv=14.7afr it's only purpose is to tell the ecu which side of stoich the car is on. Using data from this sensor to try and accurately quantify your afr's is an excercise in futility.
That's right, I forgot about the narow-band being 1v, not 5v. by bad. previous post edited.
Nate
Old Feb 16, 2005 | 10:07 PM
  #49
Larrio's Avatar
The Definitive AE Master
rpm 7529 - 13.1 A/F
the lowest I saw at that rpm was 12.7 A/F while skimming through that file
Old Mar 16, 2005 | 10:48 PM
  #50
IceY2K1's Avatar
SR - Do you mind smacking this guy for me by posting up your log again?
http://my350z.com/forum/showpost.php...&postcount=199
Thanks....
Old Mar 17, 2005 | 05:07 AM
  #51
SR20DEN's Avatar
VQ Wizard
Old May 19, 2005 | 01:44 AM
  #52
choray911's Avatar
The Crazy Azz Cracka
Now that you have had time to play with the data logging, what is your opinion? Here in the next few weeks I'll be swiching to Emanage but I need a wb to track a/r. Tell me what you think.
Choray
mclasser
22
Nov 12, 2020 01:58 PM
BkGreen97
Apr 2, 2016 05:47 AM
rbaker100
Sep 25, 2015 07:52 PM
ColdCananda
Sep 20, 2015 10:45 PM
Maxboy23
Sep 4, 2015 06:04 PM
