How much hp can a 2.5" exhaust system handle?
Old Feb 25, 2005 | 12:13 PM
JClaw's Avatar
Title says it all. I heard that it's better to have a little restriction than have something too big. I should have about 250whp. I am sure that the 2.5" I have is fine for that amount, but how much could I make with a 2.5" system without having too much restriction?
Old Feb 25, 2005 | 12:17 PM
Jeff92se's Avatar
I'm needing a caw
You do know that na and boost applications are different right?
Old Feb 25, 2005 | 12:23 PM
JClaw's Avatar
Yes, but I wanted a rough idea. I don't think no one will ever be able to make enough power NA to max out a 2.5", but what about boosted?
Old Feb 25, 2005 | 12:27 PM
Jeff92se's Avatar
I'm needing a caw
I think 2.5" should be fine for 3.5 liters of displacement. Boost. Some go to 3" with good gains. But when boosted, you don't have the same problems with exhaust gas velocities as you do with na. Hard to compare the two.
Old Feb 25, 2005 | 08:10 PM
sleeper's Avatar
with single exhaust like the maxima's probably around 350 to the wheels. duel exhaust would be more.
Old Feb 25, 2005 | 08:15 PM
Stephen Max's Avatar
I put down 358 hp to the wheels with a 2.125" b-pipe and 2.36" axle-back.
Old Feb 25, 2005 | 09:52 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Stephen,
You need to drop the cat for a run once you're back on the dyno. I'd bet it makes a big difference.
Old Feb 25, 2005 | 09:57 PM
Originally Posted by IceY2K1
Stephen,
Yeah, I'm interested in what that would do. That would be incredibly loud, too.
Old Feb 25, 2005 | 10:02 PM
chris'smax's Avatar
Stephen,
Hopefully with the VES i can get us a good dyno comparison in the next couple of weeks. Just waiting on the headers to be delivered on monday hopefully.
Old Feb 25, 2005 | 10:27 PM
IceY2K1's Avatar
Stephen - Yes, loud however not REALLY loud until you go WOT. We had a 5th gen on the dyno with headers, stock cat, bpipe, and no rear section and it wasn't too loud until he opened it up. However, it was a closed room with the car facing out, so the sound had no where to go. Also, the sound definitely changed with a high flow cat. SC would probably make noise worse, but MAN did that sound mean. You need to go 2.5" back and get a turbo muffler or IMHO the best compromise between sound and flow is a flowmaster.
Chris - Yes, I'm still looking forward to how yours turns out.
Old Mar 6, 2005 | 10:33 PM
DirtyErnie's Avatar
here's the drill: boost increases your effective displacement (makes your engine act bigger than it is). http://www.flowmastermufflers.com/cg...ml?id=94nnFimb
that's a nice chart to find horsepower against displacement to get ideal exhaust pipe size. remember, atmospheric pressure is close to 15psi absolute. if you're boosting to 5psi, that's an additional 33% in pressure, which equals an additional third in engine displacement. making your 3.0liter (180cid) act like a 4.0 liter (240cid). 7.5psi adds 50% (3.0 is now 4.5) and so on. Exhaust size is still important on a supercharger/blower, you can have too much. On a turbo, the bigger the better, and no flowmasters on turbos: straight through only.
Old Mar 7, 2005 | 07:00 AM
LatinMax's Avatar
I have read that the headers fpr our car produced less than 2 hp and was not worth it for the money and the 8+ hours to install.
Old Mar 7, 2005 | 07:21 AM
chris'smax's Avatar
that may have been NA reviews but it has been shown by stephenmax that the headers on SC cars are far superior to the y pipe. I think he put down like an extra 30 whp w/ headers
Old Mar 7, 2005 | 09:50 AM
IceY2K1's Avatar
Chris is right Gabriel....headers are SCers best new friend.
You dyno lately?
Old Mar 7, 2005 | 09:57 AM
chris'smax's Avatar
You dyno lately?
if your talking to me, no. It seems like everything i order is on backorder. The VES is a 8 week wait since i had to send the one i got back because it was malfunctioning. Then i ordered my headers two weeks ago and have been since waiting for hotshot to deliver them to SWA. This week i am installing the Emanage, Support tool, 2.87 pulley, CAI mod, UR SC drive pulley, walboro, and the 510cc injectors. That ought to keep me busy until the other stuff finally comes in
Old Mar 7, 2005 | 10:57 AM
IceY2K1's Avatar
No Chris, I was asking Gabriel. He has an auto(built) and PE510s and pretty much everything else possible, but headers, so I'd like to see what a 5th gen gains going from a ypipe to headers.
You're going to have quite a beast there Chris...I wonder what is the 5th gen SC only dyno record.
Old Mar 7, 2005 | 12:33 PM
LatinMax's Avatar
You dyno lately?
Again I may be wrong. But from what I remember the 5ht gen gain very little with headers (and SC) over what the 4th gen do.
The 5th gen OEM headers is very efficiant (can't spell today) compared to the 4th gen headers.
Oh, no I have not just yet. But in the next few weeks I hope. Been slammed with work.
Old Mar 7, 2005 | 01:03 PM
IceY2K1's Avatar
I'm not sure what 5.0gen you're referring too, but HNDA ETR on his 2000 SC'd Max gained 22.7whp by switching from a Stillen ypipe to Cattman headers.
http://forums.maxima.org/showthread....highlight=dyno
Old Mar 8, 2005 | 06:53 PM
SPiG's Avatar
SomePsychoGuy
I always thought the 5th gen and 4th gen exhaust manifolds were the same pretty much the same except the cali spec with the precat, and that was why the 3.5 had such better gains with headers.
Old Mar 9, 2005 | 08:30 AM
JClaw's Avatar
The "displacement/boost" thing mentionned earlier just proves how much headers helps boosted cars. Cattman told me his headers work alot better on the VQ35 than the VQ30, simply because 5th gen (2000-2001) and 5.5 gens (2002-2003) have the exact same exhaust manifolds. Nissan didn't make them bigger for the bigger engine. Imagine if you're boosting 10+psi with over 5(corrected) liters of displacement...
Old Mar 15, 2005 | 03:27 PM
packetattack's Avatar
Chris, where did you buy the 510cc injectors from and what did they cost, if you don't mind telling me. Thanks.
Old Mar 15, 2005 | 03:36 PM
IceY2K1's Avatar
He got them off a eBay for an ABSURD price of $4xx.
Going rate new is $870...check www.gruppe-s.com.
BTW, these are top-feed 5th gen injectors NOT 4th gen injectors.
Old Mar 15, 2005 | 03:52 PM
Thanks for the info. $4xx is definitely a steal. Can the 510cc injectors keep up with a 2.87 pulley and 255lph Walbro fuel pump? I see some people running 550ccs. Does that extra 40ccs really make a substantial difference in the IDC?
Old Mar 15, 2005 | 04:03 PM
Mishap's Avatar
Does a '99 run top feed injectors? If it's the same as other 4th Gen Maximas you need galley feed injectors. Either look for a Deatsch modified injectors or get some Nismo 550's. We got a set of 660's from them Deatsch...haven't run them yet but hopefully in the next day or two.
You should be fine w/ a S/C and 510's. Our 370's managed 300whp and from what I've seen most S/C's reach about 350whp peak.
Old Mar 15, 2005 | 04:11 PM
vortechpower's Avatar
My factory injectors are doing ok with 10psi. I emtied out my cat the other night and wow. It is actually quiter and feels alot more responsive. I noticed that my boost gauge needle vibrates really fast when boosting. As it goes up it is vibrating. Never had this happen before. Im guessing it has something to do with my exhaust since I just changed something and fixed 2 leaks, one on each side of the cat.
thatcollegestudent
18
Oct 5, 2015 02:29 PM
ef9
Sep 29, 2015 11:29 PM
carid
Sep 9, 2015 05:06 AM
TheMafia
Sep 4, 2015 08:26 AM
A32goldylocks
Sep 2, 2015 06:39 AM
