J&S safe guard
#43
![](https://maxima.org/forums/images/smilies/support.gif)
Originally Posted by IceY2K1
I think that will work GREAT for around 300whp with or without the Z32 MAF, but you'll need to use a FMU to pump a bit more fuel through those 370cc injectors to keep safer duty cycles. See how that goes and what hp level that supports.
(370cc/10.5)*.8/.6*6*.85 = ~240whp@80%DC
(370cc/10.5)*1/.6*6*.85 = ~300whp@100%DC
I'd have no qualms about running the J&S and stock ECU with regards to timing.
messing with that equation makes me worried that even with my .4 bar wastegate spring I will be close to or out of the range of the stock injectors.
(240/10.5)*.9/.6*6*.85 = 175whp@90%DC
or, maxed out and a less conservative BSFC
(240/10.5)*1/.55*6*.85 = 211whp@100%DC
but I will be using an FMU. Lets say a 8:1 disk with my 5psi of boost which is about 65psi of fuel pressure through the stock injectors which effectively makes them 273cc injectors, so
(273/10.5)*.9/.6*6*.85 = 198whp@90%DC
or maxed out and a less conservaticve BSFC
(273/10.5)*1/.55*6*.85 = 241whp@100%Dc
I figured on a .4 bar spring (5.8psi) which will probably be 5psi after the intercooler I would be around 260-270 whp. So how in the heck is this gonna work foe me. I have an FMU and SAFC. Am I doing something wrong with these equations or something? I thought I would be safe up till 290 or 300 whp on the stock injectors and FMU.
![slant](https://maxima.org/forums/images/smilies/slant.gif)
#44
Basically, injector type, injector size/ECU programmed pulse-width, base fuel pressure, fuel system type, injector atomization/spray pattern, yada yada are different, so there isn't a XXXcc size limit via MAF conditioning.
However, there is a minimum MAF voltage point at which an eManage or similar piggy-back can not go below because the stock ECU will think the MAF has crapped out and either go into limp mode or idle bad. Therefore, TS/JWT can be used.
#45
No, however...
1)Base fuel pressure is 34psi, why are you using 50psi?
2)Stockers vary from 240cc-260cc, IIRC, so some have more room to work with.
3)People run more then 65psi of fuel pressure.
4)SC people probably see closer to 0.5 BSFC, so more room, but moderate-to-high psi turbo peeps should stick to 0.6 IMHO.
You said you were running 370cc injectors before at 9-10psi, however if you intend to run the 240cc-260cc injectors, I'd bump up the fuel pressure using a bigger disc ratio.
I figured on a .4 bar spring (5.8psi) which will probably be 5psi after the intercooler I would be around 260-270 whp. So how in the heck is this gonna work foe me. I have an FMU and SAFC. Am I doing something wrong with these equations or something? I thought I would be safe up till 290 or 300 whp on the stock injectors and FMU.![slant](https://maxima.org/forums/images/smilies/slant.gif)
#47
why do you guys waste your money on that useless SAFC?
Get an emanage for what $300 plus shipping, the injector harness so you can control your larger injectors and call it the day. If I was to get a JWT ECU I would just get the extended rev limiter to 7500K, that extra cushion so you dont have to stare at the tach when you are running someone.
#50
Actually, double checking with my calculator shows at a peak 65psi of fuel pressure, that would make 240cc-->~293cc.
So,
(293/10.5)*.9/.6*6*.85 = ~213whp@90%DC
(293/10.5)/.55*6*.85 = ~258whp@100%DC and 0.55 BSFC
So,
knight_yyz
11-01-2015 01:34 PM
Andy29
09-29-2015 05:32 AM
