Dyno results
Dyno results
Good results. 260 whp & 260 wtq @ 5psi
My AF was pretty good right out of the box, it is the leaner of the two set ups shown below. That was an 8:1 FMU disk and no SAFC corrections. Just a bit too lean at the end. The SAFC could not add anymore fuel because my stock injectors are maxed out.
So we tried going to a 10:1 disk and pulling fuel. A little on the rich side but a safer tune for vairables that will change when on the street. The down side to that was I had to correct up to 18% with the SAFC in some places. I did not want to correct that much with the SAFC.
I will probably run the richer of the two. The power is about the same so it is not a big deal either way. I will only have this set up for a month or so. I got 370 injectors on the way, and will pick up an 8psi spring and Z32 MAF soon. I would see 300 whp/tq with that.
Jeff- Car drives fine. The turbo has had little effect on the car's abitlity to be a dialy driver. Ground clearance is my biggest issue.
Turbo is fully spooled by 4K
From what I have read, 370's and the Z32 MAF work great together until a lean condition in the upper rpm's when running moderate boost levels. I plan to just use a 3:1 or 4:1 FMU disk and/or S-AFC
I got hooked up pretty good at the is dyno place too. BriGuyMax is friends with the owner. We spent about well over 2 hrs on the dyno and about 10 pulls for $100.
Originally Posted by 96sleeper
I bet seeing that power fall on the top end makes you sick. But, I guess if the MEVI helped you finance the turbo project, then it was worth it. good results, congrats.
Just to clarify, this is not a PFI kit, but it is a simliar setup?
So does this kit have the same, worse, or better ground clearance than a PFI kit?
Thanks for sharing your info!
Originally Posted by Prodeje79
Nice numbers!
Can't wait till the track......
WooooooooooooooooooooooooooooW
I've been gone to long. I just got back from Cail. from spring break, just saw this thread. Glad to see you got every thing up and running cain't wait to see this in person. So when do you plan on pushing more hp? I know you got the bug for more Just keep up the good work, another turbo I30 on the map
TallTom
50
07-08-2022 09:54 AM
04-16-2020 05:15 AM
03-12-2020 12:06 AM
mkaresh
03-12-2018 06:48 PM
