I'm ready to ditch the Blitz SBC-ID
Old Jun 21, 2005 | 01:09 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
It's a crappy feeling when you fix one issue and another starts.
Issue #1: Wastegate opens at idle sometimes for what appeared no reason - Turns out that it was because the wastegate and the boost controller had 2 different vacuum sources. That difference was enough to cause it to open. I fixed it by tapping the vacuum @ the turbo compressor port. Boost would come on fine, it would hit dead on whether it was 7 psi, 10 psi, 14 psi etc... it never undershot or overshot at all.
Issue #2: Now, the car won't boost past about 9.5 psi. As far as I can tell, there are no boost leaks. At idle, it idles fine, 18-19 mm HG. I took apart the SBC-ID solenoid and the solenoids don't smell burnt or anything. I siliconed all the fittings that the SBC-ID gets vacuum/ boost readings from, so it's not that. I'm out of ideas here. I went ahead and ordered a 10 dollar manual boost controller to see if I can get more boost, which would eliminate a Boost leak issue, I guees I can isolate that possibility when the MBC arrives this week. Anyone have this problem with the SBC-id, or any suggestions?
Old Jun 21, 2005 | 04:33 AM
crewchief264's Avatar
my buddies prelude would only make 70% boost due to a couple things.
exhuast waste gate gasket leak
found a couple leaks near the fuel psi regulator-vaccuum
Old Jun 21, 2005 | 10:55 AM
turbomax97's Avatar
Definately not leakin g@ the wastegate. I guess I'll go and ziptie EVERYTHING vacuum related
Old Jun 21, 2005 | 08:56 PM
turbomax97's Avatar
Found something interesting. The rubber gasket between the upper/lower intake plenum can be moved around etc... Guess I'll either get a new one or tighten this one down.
James92SE
142
Jan 2, 2024 09:23 AM
sliptap
Sep 30, 2015 05:57 AM
Vequity
Sep 10, 2015 05:26 AM
