wastegate spring rate
Originally Posted by I30tMikeD
It depends on some things. What can your fuel set up handle? How much boost do you want to run? Do you have a boost controller?
I use a .4 bar spring w/ no boost controller.
do i need to get two fpr's?
![](https://maxima.org/forums/images/smilies/support.gif)
Originally Posted by mingo
i plan on using a boost controller. i'm not sure which one yet, but definately not the avcr. i've had alot of problems with those in the past. i plan on running around 12psi after i get injectors but before then, just around 4psi. all i have now is the cartech fmu and the walbro 55...
Ideally you want to run the wastegate spring as close to your desired boost level as possible for the reason mike gave, but also you may want to be able to turn the boost down some if you are having problems or whatever so keep that in mind, and you obviously can't run less boost than your wastegate spring is. Just get a low boost spring for if you need to fall back to a low boost level, and a higher boost spring for when your car is running well. They only cost like $15.
MaxLvr21
10-17-2015 12:11 PM
