Is a 100 PSI Fuel Pressure Gauge enough when running a small pulley?
Old Jul 28, 2005 | 11:41 AM
Guys,
I'm about ready to take the plunge and order some gauges. My question pertains to fuel pressure. I know that being boosted raises our fuel pressure quit a bit when at WOT, so.... is a 100 PSI Fuel pressure gauge enough? Right off the bat, I think I'm going to be close to 100 psi (I'm currently using the 3.25 pulley), so I'm thinking I may need a gauge that goes up to about 130 PSI. Yes/no considering I plan on putting on a 3"/2.87" pulley on here shortly? Finding a gauge that goes that high really limits what's available.
Thanks in advance.
Old Jul 28, 2005 | 11:52 AM
BlackCat's Avatar
RIP '98 Maxima SE
I've got a 100psi gauge with my 3.125" pulley. I don't think it hurts to have a 130psi gauge either.
Old Jul 28, 2005 | 12:17 PM
Stephen Max's Avatar
When 100 psi fuel pressure gauges aren't enough, it's time to start thinking about larger injectors.
Old Jul 28, 2005 | 12:24 PM
matty's Avatar
Perfectly said
I was running 95 psi on my stocks...Now with my 370's I'm at about 60-65 psi
-matt
Old Jul 28, 2005 | 12:30 PM
Matt93SE's Avatar
STFU n00b!
As Stephen Max said... if you're running that kind of pressure, you need to get the proper injectors and dial back some of that fuel pressure.
your fuel lines and pump aren't designed for that kind of pressure.
Old Jul 28, 2005 | 01:00 PM
Thanks for the input guys. So, what are the proper injectors given my level of mods/plans? 370's?
Just a FYI, I'm dropping pulley sizes right after I install the water/air aftercooler. The drop in pulley sizes will compensate for any boost losses due to the aftercooler, and since it's safer boost with an aftercooler, that's even more reason to drop pulley sizes.
P.S. Matt. I love that guy killing himself at the computer! I laugh everytime I see it!
MattWithTheMaxima
Jun 30, 2017 01:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
