VQ30DET and VQ30DE differences?
Old Jul 31, 2005 | 08:20 PM
thisisausername's Avatar
I'm aware that the T means it has a turbocharger but does anyone know the difference in internals between the two? Could this be proof that it is safe to run moderate boost on a VQ30DE or are the internals inside the T substantially different? Im guessing the answer is a no, but is it possible to take the turbo from a T and use it on our engine?
Old Jul 31, 2005 | 08:24 PM
THT's Avatar
THT
Throbbing member
Lower compression heads. Different upper IM. That's all I know.
Old Jul 31, 2005 | 08:40 PM
Alex_V
Its very ok to run boost on VQ's. All the max motors are very strong. VG-VQ all strong motors. No problems up to 400FWHP from what Ive seen, just do more research on the forums. 5-8lbs is nothing to these motors.
~Alex
Old Jul 31, 2005 | 10:45 PM
Nealoc187's Avatar
SLOW
5-8lbs is only like 250-320hp. You can run alot more than that safely
Old Jul 31, 2005 | 11:17 PM
maximazation's Avatar
isnt mardi pushing 16.5 psi WITH nitrous?
Old Aug 1, 2005 | 09:57 AM
SPiG's Avatar
SomePsychoGuy
The heads are the same cc. They might flow slightly better, or have better cams or something, but I don't know for sure. Tilley should know since he had one in his car.
It has lower compression pistons. Beefier rods (thicker and bigger hole for crank) and stronger crank. Some 350Z guys actually de stroke their engines and use the VQ30DET crank and rods.
I know the manifolds are different as well. The IM has almost no runners and the exhaust manifolds go straight back.
Old Aug 1, 2005 | 01:08 PM
gameover03's Avatar
is it possible to get that engine here?
Old Aug 1, 2005 | 01:27 PM
Deagle's Avatar
wants the ads to die
The 300ZXTT has it, so yes. I'm unsure if any other Nissan's carry it.
Old Aug 1, 2005 | 01:28 PM
wunfstmax's Avatar
not with out more money than your probably willing to spend
Old Aug 1, 2005 | 01:29 PM
wunfstmax's Avatar
the 300zxtt has a vg30dett. and a much much different design.
Old Aug 1, 2005 | 01:36 PM
96sleepergle's Avatar
yes it is but you would have to make it work because it is rwd too much money.
Old Aug 1, 2005 | 01:38 PM
Deagle's Avatar
Ah, I didn't know there was a single turbo VQ30. What car(s) was it used in?
Old Aug 1, 2005 | 01:42 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
to make it fwd, you just need to change the oil pan. the bolt holes should line up.
ask tilley, he did the det swap.
Old Aug 1, 2005 | 02:20 PM
wunfstmax's Avatar
I believe they are in the nissan gloria and cedric.
Old Aug 1, 2005 | 03:23 PM
Nealoc187's Avatar
SLOW
Yes the gloria and cedric had them, not sure if others did. The 300ZX is a VG, we are talking about a VQ here, nothing similar between the two.
Old Aug 1, 2005 | 05:30 PM
Kevlo911's Avatar
Kevlo for President
The base Cima(Q_)
Old Aug 1, 2005 | 09:38 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
http://cgi.ebay.com/ebaymotors/JDM-N...QQcmdZViewItem
Old Aug 2, 2005 | 07:25 AM
Kevlo911's Avatar
Kevlo for President
So the DET has a 55mm crank like the VK45 and VQ35?
Old Aug 2, 2005 | 10:36 AM
gameover03's Avatar
so how difficult is the installation? what about ecu.s and regular maintenance parts like spark plugs and oil filters..is it essentially the same as the vq30de-k
Old Aug 2, 2005 | 04:40 PM
Nealoc187's Avatar
SLOW
Did you miss the part where we told you that engine is for a rear wheel drive car? Meaning it sits rotated 90 degrees from how a FWD engine sits. No it won't even be close to fitting in your car, everything would have to be completely custom. Drop the idea. If you really want DET stuff you can take the engine apart and use the internals, but externally, it won't fit any better than it would fit in your lawn mower.
Old Aug 3, 2005 | 09:15 PM
SPiG's Avatar
SomePsychoGuy
Tilley took almost every internal and swapped it over to the FWD block. Unless you are really crazy turbo and need a built engine, but for some reason are too cheap to actually put forged custom stuff in there.
The Exhaust manifolds would be good to get for a turbo setup to make it easier to fun the up pipes. The intake manifold would be good too, but you would need a custom hood. But I would rather just get some custom turbo headers for the price of buying the engine.
This engine would be GREAT to put in a 240sx though. There would still have to be some custom stuff, but easier than the FWD engine and it is already setup for turbo.
Old Aug 7, 2005 | 01:29 PM
TILLEYS99's Avatar
Lives in a 11sec maxima
the exhaust manifolds wont work on fwd due too front motor mount.
Old Oct 30, 2021 | 03:06 PM
Mat's Avatar
Mat
I have a 1996 nissan gloria it has a vq30det.
Old Oct 30, 2021 | 03:28 PM
95naSTA's Avatar
The post you quoted is old enough to get its driving license.
litch
123
Jan 4, 2024 07:01 PM
mkaresh
Mar 12, 2018 06:48 PM
doctorpullit
Dec 12, 2015 09:39 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
