Got the Cartech FMU, Aeromotive FPR and Walbro 255:Anything else I need?
Old Aug 12, 2005 | 12:49 PM
BlackCat's Avatar
RIP '98 Maxima SE
I've read through most of the old threads on tuning and accumulated the items in the title and AN connection pieces for the Aeromotive FPR. The last thing I need are the hoses. I don't plan on getting 370 injectors as I just want to stay with the stock injectors. Am I missing anything else?
Old Aug 12, 2005 | 07:55 PM
matty's Avatar
370's are key...your car will act and feel a he*l of a lot better....With the price is these things around $180-$230 lately it makes a word of sence.... I personally have seen about 4 sets recently and Im not even shopping for them...
-matt
Old Aug 12, 2005 | 10:40 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Blackcat, that's all you need....
Edit: I don't know if you got this already, but you need the fuel rail fitting.
www.sx7r.com
Old Aug 13, 2005 | 08:07 AM
BlackCat's Avatar
RIP '98 Maxima SE
Oh yeah, thanks for the info guys! I forgot to mention that I did pick up the fuel railing from sx7r.
Old Aug 16, 2005 | 11:19 AM
BlackCat's Avatar
RIP '98 Maxima SE
If I ever do get 370cc injectors, I guess I'll then need the JWT ecu, SAFC and Z32 MAF? Is that correct?
Old Aug 16, 2005 | 11:49 AM
matty's Avatar
If your 5spd you can buy mine when I go Emanage in a few months
-matt
Old Aug 16, 2005 | 11:54 AM
1FSTMAX's Avatar
you can do it without the jwt ecu..
Old Aug 17, 2005 | 10:27 AM
BlackCat's Avatar
RIP '98 Maxima SE
Would a 370cc injector from a blacktop sr20det work?
http://www.northwestnissans.com/boar...ighlight=370cc
Old Aug 17, 2005 | 10:55 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
yes, those will work.
Old Aug 17, 2005 | 11:38 AM
BlackCat's Avatar
RIP '98 Maxima SE
When dealing with used injectors, should they be flow tested before purchasing?
Old Aug 17, 2005 | 12:23 PM
slimer's Avatar
you should because they ultrasonically clean them too, sometimes they flow test to more than what they were originally rated at. I used to use witchhunter, he puts new pintle caps and o-rings on them, but he sends them dry, which isn't good for the injectors. I would pm superdave2 because I think that he now has an ASNU machine (what they clean and flow test them with.) He sends the injectors wet.
Cotozic
Jun 28, 2017 08:01 PM
BkGreen97
Apr 2, 2016 05:47 AM
msellas
Sep 23, 2015 09:16 PM
Booner8269
May 1, 2002 05:16 AM
CalsonicSE
Mar 14, 2002 12:50 AM
