Wide Band Installation
Old Feb 4, 2006 | 02:17 PM
  #41
slimer's Avatar
A couple of Blaxxx's? Lawls.
Its supposed to be pointing down, so the condensation can drip. Makes sense doesn't it? if its at 7 o'clock its pointing up, so its not as good.
Old Feb 4, 2006 | 02:25 PM
  #42
95maxrider's Avatar
Lightly modded
Gotcha. So it should be between 9-3, but not 3-9, correct?
Old Feb 4, 2006 | 07:48 PM
  #43
matty's Avatar
I put it at 1 o clock about.
Dont put it at 3, 4, 5, 6, 7, 8 or 9. Putting it straight up is kinda hard because of clearence issues with my 3" test pipe
-matt
Old Feb 4, 2006 | 08:50 PM
  #44
chris'smax's Avatar
I was installing my zeitronix this morning and i just tapped in the 12v power wire and ground wire to my emanage. Is that a bad idea? If not matty could just tap into the power wire on the on his ecu.
Old Feb 4, 2006 | 08:54 PM
  #45
matty's Avatar
Mines already in. I used a 12V Switched source from the Ignition switch and grounded the Unit on the engine.
I like the Innovate, but its pretty bair bones. I would like an RPM reading but I guess ill get that when I get the Emanage Ultimate soon.
-matt
Old Feb 4, 2006 | 08:58 PM
  #46
chris'smax's Avatar
-matt
The zeitronix unit is great, but i still haven't been able to get the comm port selected right so it will link up w/ my laptop. It looks to be a great unit. It has rpm TPS and you datalog and overlay the graphs.
Old Feb 5, 2006 | 11:14 AM
  #47
Y2KevSE's Avatar
Rice Boy in Denial =)
This was what I meant.
The LM-1 with RPM converter (what I have) would have let you log RPM along with 5 other signals, but you're going to get the GReddy EU anyway so it would have been an overkill.
Old Feb 5, 2006 | 07:21 PM
  #48
slimer's Avatar
whats your problem with it? I haven't had an issue lately.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
2kmaximel
Sep 16, 2015 03:19 PM
DBear
Sep 14, 2015 08:33 PM
Johnny9595
Sep 3, 2015 05:18 AM
