Choice on oil w/ supercharger
Old Nov 16, 2005 | 08:07 PM
chris'smax's Avatar
I was talking to a mechanic at a local performance shop the other day and we were talking about oil myths. Now my understanding has always been that you can run non-synthetic oil w/ a supercharger, but you would have to change it more often. He proceeded to tell me that they have been to several oil seminars and there findings are that while there are certain brands that are better than others, but non-synthetic provides just as good as protection as full synth does just in a shorter term. any opinions?
I ask because i feel like i am pi$$ing money away on full synthetic when i hardly ever even get into boost since i drive like a old man(car is to low to the ground. So in my case would it be safe to run non-synth?
Old Nov 16, 2005 | 09:10 PM
chilled's Avatar
Correct me if im wrong, but I was under the impression that once you switch to synthetic that you can't go back?
If its not true then I would start running blends on oil changes for a month or two before going back to regular. Good looking car btw~
Old Nov 16, 2005 | 09:35 PM
carnal_c30's Avatar
Former Sponsor
with the high heat of boost Superchargers/Turbos its better to run synthetic oils as they break down less than comparable non synthetic oils, on a N/A car unless it is built regular oil is not a bad choice...
I run synthetic, it helps me sleep better at night
Old Nov 17, 2005 | 09:22 AM
SPiG's Avatar
SomePsychoGuy
You need to use synthetic. You spent thousands of dollars on rims, but you complain about $20 on oil.
Old Nov 17, 2005 | 10:14 AM
JAY25's Avatar
If you guys did not know a oil cooler helps out alot. You can change out your oil around 4K using synthetic oil. Dont have to take my word for it. Just buy a oil cooler and send a sample in. After your first oil change.
If you have a Ballbearing turbo dont dare to put cheap regular oil in there. If its under warranty and the seals may go bad and turbonetics may not even want to honor the warranty because you were suppose to use a good synthetic oil.
Chris in Louisiana it is very hot. Id use a oil cooler from the first day you bolted that blower on there. Dont know why you have not done so?
Old Nov 17, 2005 | 04:49 PM
chris'smax's Avatar
I remember you telling me that, but i really drive like a grandpa most of the time so i figured i wouldn't need one. I think i may get one this spring though
Old Nov 17, 2005 | 04:50 PM
chris'smax's Avatar
at some point the madness must stop
Old Nov 17, 2005 | 06:38 PM
JAY25's Avatar
Dont complain about oil changes people, Every oil change for my trucks is 15 Qts plus largest oil filter you see on the autozone shelf $50 oil change every 3K on that F250 Turbodiesel truck
Old Nov 17, 2005 | 07:11 PM
AsthmaMax11's Avatar
damn jaime, that truck is expensive.
When are you gonna make it fast like your Maximas?
tell that dog of yours to stop barking at white people.
white people are your friends
-Bruce the Shark
Old Nov 17, 2005 | 07:18 PM
chris'smax's Avatar
whoaaaa gangsta, is that the same truck you told me about or is this a new one?
Old Nov 18, 2005 | 11:46 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
Mobil 1, every time.
Old Nov 18, 2005 | 11:50 AM
matty's Avatar
10W-30 In the summer, 5W-30 for the Winter both changed between 2700-3000 miles
-matt
Old Nov 18, 2005 | 12:45 PM
BigDogJonx's Avatar
If you put synthetic there is nothing that says you cant go back to convential oil and back to synthetic.
All the oils myths and things are highly opinioned. Why else you think manufacturers have been upping the oil change intervals to almost 7500 on convential oil?
Dixit
Old Nov 18, 2005 | 12:59 PM
1FSTMAX's Avatar
hahaha that's what i was thinking too.. same deal with the lugnuts..
i personally run torco oil, my car doesn't drink it like it does with mobil one.
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
