compression high...
Old Mar 14, 2006 | 03:01 AM
mjk's Avatar
mjk
Head shot!!!
compression high...
me compression tested at 230 for each of the front 3 cylinders. I think they're 2,4, and 6. Regardless of the cyl numbers, I believe I should be at around 180 and am getting worried if superchargin might be a bad idea?
thanks =]
Old Mar 14, 2006 | 03:08 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Two threads?
Old Mar 14, 2006 | 03:16 AM
mjk's Avatar
mjk
Head shot!!!
lol, in search of more power, meaning as a moderator?
anyway, anyone have any ideas... i search ->before someone asks me taht...
Old Mar 14, 2006 | 04:55 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
did you do the test right??
Old Mar 14, 2006 | 05:29 AM
Stephen Max's Avatar
I would be very concerned about compression test numbers that are significantly higher than normal (230 psi fits that description). That could be due to a lot of carbon buildup in the combustion chambers. When boosting, the carbon could get hot enough to glow and cause preignition, and you could burn a hole in a piston.
Old Mar 14, 2006 | 05:36 AM
DA-MAX's Avatar
thats why I'd retest...what number are you getting on your first "puff"??
Old Mar 14, 2006 | 06:40 AM
95turbo gxe's Avatar
besure to hold the throttle body open too.
Old Mar 14, 2006 | 06:55 AM
Kevlo911's Avatar
Kevlo for President
Seafoam that bish...
Old Mar 14, 2006 | 08:24 AM
mjk's Avatar
mjk
Head shot!!!
i seafoamed this friday, i guess ima test again soon. how many times should i crank it? should i get all plugs out, or is it enough to disconnect the coils?
thank you
Old Mar 14, 2006 | 08:28 AM
Compression tests should always be done with all your plugs removed. You will get more consistent results this way and it is easier on your poor starter.
Old Mar 14, 2006 | 08:42 AM
DA-MAX's Avatar
thank you
crank it for a few seconds until you hear 4-5 "puffs"...watch your readings, cylinders shouldn't differ by ~20% or so at most
Old Mar 14, 2006 | 11:18 AM
mjk's Avatar
mjk
Head shot!!!
okay thanks guys
aw11power
Oct 10, 2021 04:57 AM
rbuswell
Nov 17, 2016 04:54 AM
Carlos A
Jun 9, 2001 05:19 PM
JoesMAX
Mar 2, 2001 01:31 PM
kaleb
Sep 2, 2000 01:41 PM
