My Emanage Ultimate is here! -Part 2- *MAJOR UPDATE*
Old Apr 22, 2006 | 11:44 AM
  #121
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Are you using Duty Cycle or Injector Pulsewidth?
Are you using the Add Injector map to add fuel from 6400-7000rpm or just the RLC map?
Do you have any logs?
Also, have you posted the dynos?
Originally Posted by jeremykedel
Icey you apparently dont understand what i am saying.I have adjusted the RLC map numerous amounts on and off the dyno.It brought down the a/f to 13.3 but i cant get it to 11.7 without the timing signal to read the timing off a log then adjust from there.I know what has to be adjusted I just am waiting patiently.
Dandy has done a great job and my applause for all the hard work.
I had some problems to start off like a faulty unit but other than that i have had a success with the EU.
Old Apr 22, 2006 | 11:59 AM
  #122
jeremykedel's Avatar
I used both maps to adjust,I dont have any logs i am going to wait till the update is out i turned off the rev limit for now till it is out.As far as the dynos I didnt post the last one but kevlo and I are going to go to a dyno jet in the next few weeks hopefully and do some more tuning.I am using duty cycle.
Old Apr 22, 2006 | 12:08 PM
  #123
matty's Avatar
Do you guys have a picture of your setup and all your wires ??
-matt
Old Apr 22, 2006 | 12:28 PM
  #124
IceY2K1's Avatar
No offense, but you're not doing something right then. I can make my injectors go static between redline and whatever rev-limit. That or maybe your fuel system isn't capable? I think you said you have 550cc injectors, so maybe your fuel pressure, got Walbro?
For consistency, do NOT use duty cycle, use pulsewidth. Duty cycle is related to RPM, therefore it will vary as RPM changes. IPW doesn't.
You can wait for the new update, but sounds like Dandy isn't too sure it will fix the RLC map. You're probably waiting for the next update. If you could get a few logs and the current EU file, I could probably tell you what you're missing.
Old Apr 22, 2006 | 12:41 PM
  #125
IceY2K1's Avatar
Jeremy,
To keep from whoring another one of Dandys' threads to death, continue back here where Kevlo and I were discussing what was wrong:
http://forums.maxima.org/showthread.php?t=464042&page=3
Old Apr 22, 2006 | 02:06 PM
  #126
i am not that worried about discussing it anymore.i appreciate it,though thanks.
Old Apr 22, 2006 | 02:26 PM
  #127
IceY2K1's Avatar
It's a turbo car...you don't NEED the rev-limit increase anyways, I guess.
Old May 16, 2006 | 05:39 PM
  #128
DandyMax's Avatar
3.5 in the works
Small update
Well I've been wondering what's taking so long with the new update so I talked to Greddy again.
Unfortunately it's going to be another couple weeks at least as they are trying to roll several updates into one it sounds like and they're still working on finishing them up. Not sure if it will be released as 1.15 or 1.16 but I have seen at least 4 or 5 different versions of 1.15 beta so now I know why.
I can say though that it looks like a new and useful revision will be included:
- There is a new map that I believe will make the MAF to MAP conversion a lot more user-friendly and quicker. I'll have to test it and verify that that is indeed what it's for, but it looks like instead of having to do a lengthy datalog and then pick representative points for various load cells, this 16x16 "data sampling" map will fill in automatically as you drive around. Not sure how it will pick the numbers though.. ie will it average some readings or just overwrite with the latest value, will have to see once I get a chance to try it out on my car. Looking at the options I suspect there may be other uses as well.
Finally, I reported before that timing adjustability would increase to +/-40. Well apparently I was misinformed. It sounds like that was in relation to the datalogger range or something.. I didnt quite get a clear answer there. But anyways, on the timing adjustability I'm still not sure what it will end up as (20 or 30?) I've raised this issue and Japan will have to verify/correct, but it's a minor issue.
I'm sorry to have to say "be patient" again, but I've seen almost a new beta a week now so it is being worked on diligently and shouldn't be TOO much longer. The delay in the update should not deter anyone from getting an EU if they were planning to though (IMHO).
Old May 16, 2006 | 08:28 PM
  #129
mforrest100's Avatar
Sounds good. To think I almost forgot about this thread.
As always, keep up the good work.
Mike
Old May 16, 2006 | 10:22 PM
  #130
mingo's Avatar
great update =D.
Old May 17, 2006 | 10:26 AM
  #131
IceY2K1's Avatar
I'm not sure what you mean, since the previous versions RLC map could use duration/pulsewidth.
Originally Posted by DandyMax
- The rev limit map can now be programmed directly with pulsewidth, not just duty cycle.
Old May 17, 2006 | 02:39 PM
  #132
DandyMax's Avatar
3.5 in the works
You are right, must have been on crack when I posted that last night. Not sure why I got thinking it wasn't available before... Just a brain/memory fart I guess.
Old May 17, 2006 | 02:47 PM
  #133
IceY2K1's Avatar
No biggie...any news on the RLC map changes?
Old May 18, 2006 | 07:11 AM
  #134
DandyMax's Avatar
3.5 in the works
Sorry not yet...
Old May 25, 2006 | 09:31 PM
  #135
DandyMax's Avatar
3.5 in the works
Since I've been getting questions and it's come up in discussions, I'm going to post a couple reference pictures to keep everything in one thread.
IIRC Icey posted a similar pic of his elsewhere but the first pic below is my EU board, showing the resistors wired onto the 6 EU ignition input pins and grounded on the EU ground pin. The resistors will need to be added if a primary ignition signal code (P1320 (0201)) is thrown by the ECU. They should be around 330 to 370 ohms and either 1/4 or 1/2 watt resistors. Credit goes to John at J&S I believe for first suggesting this fix.
The second pic is my EU harness, showing the d-sub connectors I used for the install. I wanted a system whereby I could quickly and easily take the EU in and out several times, and the d-subs also have labelled pins, making the organization of the wiring easier. You will see there are two 25-pin connectors (mainly for all the input and outputs --ie intercepts) and one 15-pin connector for the taps. On the car side (ECU harness wiring) there is a similar setup to match. Therefore to remove the EU, all three connectors are pulled apart and the two larger connectors on the ECU side are simply put back together to complete each line's circuit. This was a good solution for me since I was testing and playing around a lot. Others may wish to go a different route but I just thought I'd post it in case anyone is interested since it has come up and people have asked me.
Old May 26, 2006 | 05:27 AM
  #136
hightuner's Avatar
Nissan maniaco conpulsif
Is this correct , they are all linked to the same ground , is all 95-96 getting the code
Old May 26, 2006 | 07:35 AM
  #137
DandyMax's Avatar
3.5 in the works
Yes.
Don't know for sure but it seems to be that way... you'll find out.
Old May 26, 2006 | 11:08 AM
  #138
hightuner's Avatar
Thank you sir
do i have to check the light on the ecu or the CEL will come out if i have it
just curious
Old May 26, 2006 | 11:32 AM
  #139
matty's Avatar
Thank you sir
just curious
The CEL will come on, run the code and if its that, then you need them
-matt
Old Jun 16, 2006 | 03:11 PM
  #140
DandyMax's Avatar
3.5 in the works
Just a small update.
I have the remote datalogger working now via the switch terminal on the front. I did not buy Greddy's switch.. just made my own. All you need is a momentary (pulse type) switch and a 1/8" male stereo mini plug. Wire the switch up between the tip and the ground (base) on the plug. Then, you can start and stop the datalogger automatically on the EU with the switch without having the laptop in the car. One pulse to start, and another one to stop. While the EU is datalogging you will see the LED on the left change from steady green to a flashing yellow to confirm it's working. You do have to set the datalogging parameters and interval ahead of time (it's not unlimited like with the laptop connected). There are only 8 parameters allowable at once (max) and the recording interval (min 20ms) will determine the amount of time you can log.
It's interesting that a stereo plug is used, since it might theoretically allow 2 different switches to be used off the same plug, if the EU is wired internally for it. I am going to find out more about this. The software and manual are a bit ambiguous as remote switch, switch 1, switch 2, external switch, and just plain switch can be found listed for various features etc.
EDIT: I have an answer from Greddy. The stereo plug is only programmed for the tip, not the barrel. And switch 1 and 2 refer to the option ports. It is possible to use them as a switch via using an A/F harness although Greddy doesn't currently sell a switch for those ports. Switch, external switch, and remote switch all refer to the same 1/8" mini stereo port next to the serial port.
Old Jul 2, 2006 | 01:15 AM
  #141
DandyMax's Avatar
3.5 in the works
Another 2-step video (better than the first)
I have a recent video showing the 2-step launch limiter in action at the dragstrip for those who are interested. The setting was 6400 rpm. The video is actually a full pass down the track during a bracket event with a local Z car club but it does showcase the 2-step pretty well.
2-step from 6400 rpms at the dragstrip
Old Jul 2, 2006 | 12:23 PM
  #142
liqidvenom's Avatar
brotherhood of tq
for some reason it plays that as a sound file in all my media players
Old Jul 2, 2006 | 12:34 PM
  #143
LatinMax's Avatar
Same here........
Old Jul 2, 2006 | 01:41 PM
  #144
DandyMax's Avatar
3.5 in the works
Sorry I guess the Indeo Codecs for Media Player are needed (I think they used to come standard with Windows but with XP SP2 might not...)
Click here to download the codec. Install it and it should work...
Old Jul 3, 2006 | 05:04 AM
  #145
pawnstar12's Avatar
BUY MY CARS PLEASE!!!
that **** sounds dope i cant wait till i get my car together and get the EU thats collecting dust working!
Old Jul 3, 2006 | 09:37 AM
  #146
DandyMax's Avatar
3.5 in the works
Using a Zeitronix WB with the EU
Copying some info from another thread...
Regarding the Zeitronix WB with the Emanage Ultimate: the Zeitronix is not linear so the A/F ratio will be off on the Emanage Ultimate. The EU does allow you to set different ranges for different widebands, however it is all based on a linear output voltage curve, which the Zeitronix is not.
For example, with an LM-1 or LC-1, you could tell the EU that at 0v the A/F is 10 and at 5v it's 20, and then it will interpolate all values in between based on a linear relationship (so 2.5v would be 15 A/F). This works fine for those WB's because they have a linear output, but the Zeitronix is a bit different.
Here is the output curve for the Zeitronix (from their website):
EDIT: As of Sept 1/06 the new Zeitronix now has linear output! The info in this post will now only apply to older units!
Now having said that to scare you off (lol) it is possible to configure the EU to read the Zeitronix over a useful range. As you can see from the pic above, the Zt-2 is fairly linear from about 11 AFR to about 14.7 AFR, which is where most of your WOT tuning will take place. Below and above those points the accuracy will drop off quickly, but in between it should be fairly close, only off by a couple tenths or so. For example, the pic below shows the linear relationship (line in blue) the EU would assume if you set it to 0v=8 AFR and 5v=21.2 AFR. You can see it's a reasonable approximation, and you probably wouldn't be off by more than 2 tenths between 11 and 14.7.
Old Jul 9, 2006 | 06:50 PM
  #147
MyownNismo's Avatar
Future Camaro SS owner
did greddy fix the issue with resistors.
Old Jul 11, 2006 | 03:22 PM
  #148
chad9350's Avatar
So..did I just **** away $$ on a neo :banghead:
So... did I just **** away $$ on a neo... b/c I cant do anything about ig. timing... b/c EmU is cheaper than afc and ecu flash...
Old Jul 11, 2006 | 03:25 PM
  #149
Kevlo911's Avatar
Kevlo for President
What is a Neo?
Old Jul 11, 2006 | 03:27 PM
  #150
MDeezy's Avatar
Originally Posted by Kevlo911
What is a Neo?
http://www.apexi-usa.com/product_ele...=260&pageNum=1
Old Jul 11, 2006 | 03:30 PM
  #151
Kevlo911's Avatar
Kevlo for President
Oh a fancy VAFC, yeah I would get rid of it if you can sell for the price of an EU.
Old Jul 12, 2006 | 06:18 AM
  #152
pawnstar12's Avatar
yep you did
Old Jul 13, 2006 | 05:13 AM
  #153
jmeister's Avatar
So what is the word on the firware update/release? Anything new or since the beta is "stable" Greddy's put it on the back burner?
Old Jul 13, 2006 | 07:07 AM
  #154
DandyMax's Avatar
3.5 in the works
No they have been delaying the release of the update because they keep adding various fixes/enhancements to it for several cars. I have seen version 1.15 "e" through "m" so far.
Old Jul 13, 2006 | 07:08 AM
  #155
Kevlo911's Avatar
Kevlo for President
Do you know if they are gonna fix the Duty Cycle to Duration(vice versa) conversion?
Old Jul 16, 2006 | 12:51 AM
  #156
DandyMax's Avatar
3.5 in the works
Converted to pressure sensor now, NO MAF
Well I got my conversion map programmed finally and today I went driving around just running off the pressure sensor, without the MAF hooked up. It worked very well. NO DRIVEABILITY PROBLEMS THAT I COULD DETECT AT ALL, and no MAF CEL either (the caps are for you Alex since you were skeptical about it... lol. Just kidding)
Of course I will have to retune everything now... timing, fuel, rev limit maps etc but I must have gotten pretty close with the rough maps I programmed since the rev limit extender worked somewhat ok on a few pulls to 7500 until my shifter support rod broke. I can't get the car in gear now at all. lol. (It's alright that problem has developed over the last couple weeks, I knew it was on the way out).
Will post more once I have a chance to more fully tune it and go for some additional test drives, but all the signs point to a successful conversion.
Old Jul 16, 2006 | 01:29 AM
  #157
IceY2K1's Avatar
Keep me updated once you do some hot starts, cold starts, decent changes in altitude or temperature.
Keep up the good work!
Old Jul 16, 2006 | 02:48 PM
  #158
MardiGrasMax's Avatar
Nice!!!!!!
Old Jul 16, 2006 | 02:50 PM
  #159
Kevlo911's Avatar
Kevlo for President
How the hell did the rod break? lol rusted? Maybe I should go cable shifter route
Anyways, congrats on the MAP. Me and Jeremy need to get that runnin on his car if you have any tips And I need help with my revlimit
Old Jul 16, 2006 | 10:25 PM
  #160
505max94se's Avatar
Is it possible to use this with the VE30DE? I have a JWT ECU right now and I HATE it. The raised rev limiter is nice but that's about it. They replaced the factory knock timing map with the same, agressive timing map they use for no knock conditions. If set the base timing to a factory advance of 15 degrees then it's pings like a **** an hot days. It seems to be ok when I pull it back 2 degrees. My motor only has roughly 85k mi. on it and it's as clean as a whistle.
