S/C FMIC installed today
Old Apr 6, 2006 | 03:03 PM
  #41
vortechpower's Avatar
That looks really nice! Go for the 2.87
Old Apr 6, 2006 | 03:37 PM
  #42
JdoubleOe703's Avatar
teddibear703
how much did you get your intercooler for?
Old Apr 6, 2006 | 03:57 PM
  #43
SlamdMax98's Avatar
it was like $150 from a friend who had bought it brand new and just had it sitting in his garage taking up space
Old Apr 6, 2006 | 06:49 PM
  #44
teddibear703
TJ max:
hey,
my paypal is teddibear703@yahoo.com
I can ship tomorrow if i get it today
thanks
BTW: ur box is full
Old Apr 6, 2006 | 07:12 PM
  #45
liqidvenom's Avatar
brotherhood of tq
Originally Posted by TJ_Max
Werd, it's right where the driver's side bumper light would go. I think I see it in the pics you posted. What size pulley you running also? If you normally see 10psi, i'm guessing it is the 3.25" pulley. I have a 3" charge pipe and it gets insanely hot since it is so close to the radiator. Did he use any welds while doing this or is everything done via couplers? 8psi kinda discourages me. That isn't too far off from stock SC setup. .
well tj the 8psi isnt the issue, its having much cooler air which would allow u to advance timing to make better use of the 8psi as opposed to less timing and hot 10psi air
Old Apr 7, 2006 | 07:29 AM
  #46
TJ_Max's Avatar
Paradox Systems Vendor
Would you say "good" timing @8psi is greater than/equal to less timing at 10psi?
Hope so as I just ordered my FMIC. I'm doing it because I'm giving up on performance and going for the show car look. But if this is STILL great for performance, then I might keep on trucking with the performance.
Old Apr 7, 2006 | 07:34 AM
  #47
ptatohed's Avatar
Licensed to Spell
:o)
I would drop pulley sizes and have 10PSI of intercooled air.
Old Apr 7, 2006 | 07:38 AM
  #48
Flava_24/7's Avatar
Boosted Panda
Looks good SlamdMax98, it should definately help out in the TX heat.
Old Apr 7, 2006 | 07:40 AM
  #49
TJ_Max's Avatar
True, but then you will never ever see 12psi ever. I want 12psi of intercooled air without that hazardous 2.62 pulley.
Old Apr 7, 2006 | 07:51 AM
  #50
huh?? By adding the intercooler, you lost psi. To get to 12 psi intercooled, you're going to need the "hazardous" 2.62 to say the least. Hopefully, I'm understanding you correctly. And FTR, there is a 2.47 pulley available.
Old Apr 7, 2006 | 07:59 AM
  #51
TJ_Max's Avatar
Ha ha, that's crazy. Don't we overspin the blower or something at 2.87? let alone 2.62 or 2.47. I was hoping 12psi is enough charge to KEEP the 12psi all the way through the FMIC to the TB. I always thought the more boost you are running with the IC, the less of a psi drop you get. I.E. at 10psi he lost like 1.5. but at 11psi, he would lose 1psi, and at 12psi he would lose only .5psi? I wonder if this is true. Maybe the physics guys can come in here and simplify what is in the 48 "Intercooled SC" stickies.
Old Apr 7, 2006 | 10:15 AM
  #52
liqidvenom's Avatar
brotherhood of tq
im not the best one to explian this since i have no experience with adjusting timing on a boosted maxima. but in a nut shell its like this, this get to hot then u run the risk of pre-ignition and detonation and some other things that may run amuck in a motor. but if ur able to cool the air enteriing ur tb then ur able to run the motor abit harder since u have a higher ceiling before u reach a point of trouble. so normally boosted guys tend to pull timing when they boost but if u can chill the air going into the tb back near ambient temps then u can add more timing to make up for the loss actual boost.
and i could be mistaken, since im still a bit drunk and having a hard time putting this together but u can fit more molecules of cooler air in a given space as opposed to the same air at a hotter temp. if wat i just typed is correct then running the 8psi chilled on its own should give u an added benifit aside from havig to add timing.
but as i said...im still a bit drunk so ill look this over later tonight an revise it if it comes off looking dumb or hard to follow
Old Apr 7, 2006 | 10:21 AM
  #53
liqidvenom's Avatar
brotherhood of tq
u lose a % of boost.
so is like some much boost entering the ic-remove- the % of boost drop cause by the ic= the amount of boost u see after the ic.
so if in some cases u run 10psi...and loose 2 thus u lost a 20% worth of boost due to the ic being there..u can work an equation from that which can roughly give u an idea of what u would lose at 12/14/16/18/20 psi
but since there should be no leaks in your system the actual amount of air from s/c to tb is the same regarless of u having the ic there. its just as the temps drop the pressure that same amount of air produces is decreased....i guess
Old Apr 7, 2006 | 10:29 AM
  #54
SlamdMax98's Avatar
makes sense to me, if i remember correctly when StephenMax had dynoed right after installing his intercooler on his s/c setup, his HP levels remained the same but he did lose a few ft-lbs of torque, but overall his temperatures were a lot cooler than they were before, especially down here in TX
Old Apr 7, 2006 | 10:31 AM
  #55
TJ_Max's Avatar
Any preference in the piping to the IC? Diameter wise? 2.5" is standard? where should that blower outlet 2.75" to 2.5" reducer be put?
Old Apr 7, 2006 | 10:34 AM
  #56
SlamdMax98's Avatar
ive pretty much got a place racing cold air intake setup from the throttle body and down into the fender, and then everything else from the bov to the supercharger is 3" with a 3" inlet/outlet on the intercooler
Old Apr 7, 2006 | 10:38 AM
  #57
TJ_Max's Avatar
Now I have to buy one off of friggin ebay since Jeff at Max tuning took ALL my extra parts during SC install.
Old Apr 7, 2006 | 10:40 AM
  #58
SlamdMax98's Avatar
just give him a call and see if he still has your parts sitting around somewhere, or if he has anything else that will get the job done for you
Old Apr 7, 2006 | 11:02 AM
  #59
TJ_Max's Avatar
I called Jeff, he is gonna look for em. Since now he is moving. Cool guy .
Old Apr 7, 2006 | 11:35 AM
  #60
teddibear703
i also have silicone couplers and t-bolt clamps... hehe
Old Apr 7, 2006 | 11:38 AM
  #61
TJ_Max's Avatar
LOL, gee thanks for mentioning that now. If they are cheaper than on ebay, you might have a deal, lol.
Old Apr 7, 2006 | 12:58 PM
  #62
teddibear703
well, i sell on egay too... lol and i'm the cheapest there
Old Apr 18, 2006 | 06:13 PM
  #63
ewuzh's Avatar
Subscribing. Thinking of doing a smaller intercooler so I can keep the bumper support. 13psi is going to be hot hot, especially in summer cali weather.
Old Apr 19, 2006 | 07:35 AM
  #64
TJ_Max's Avatar
Get one from JdoubleOe703. I bought mine from him, came brand spankin new. It's got 2.75" inlet/outlet, 26X2.75X6. I test fitted it and I can even keep my fogs with this cooler. Fogs and bumper support. .
Old Apr 19, 2006 | 07:47 AM
  #65
Cool. What are the flow specs for your intercooler?
Old Apr 19, 2006 | 07:57 AM
  #66
TJ_Max's Avatar
I haven't even measured the cooler. I just started to polish it out the box, lol. Anyway, I think it is very similar/identical to the one on ebay. So i'm assuming it has the same flow specs:
All TIG Welded 6061 Aluminum.(PSi Drop under 0.2. Other Intercooler usually drop 10Psi Some are More) Max PSi is 30 Up to 400HP.Core Size: 22"x5.5"x2.5"Inlet OverAll Size: 27"x5.5"x2.5"Inlet.
I don't know where they get 400hp from. But anyway, those are the specs on the one that looks exactly like mine on ebay.
Old Apr 19, 2006 | 11:22 AM
  #67
teddibear703
my intercooler is prepolished... was it not shiny enough??
anywways, i only had two intercoolers of that size. I have 2 larger ones though...
Old Apr 19, 2006 | 11:29 AM
  #68
TJ_Max's Avatar
Yeah it was real shiny. But I got it to that mirrored polished look.
Old Apr 20, 2006 | 10:25 AM
  #69
teddibear703
sweet... ....put a coat of clearcoat on it, or itll loose the luster quick....
Old Apr 20, 2006 | 10:30 AM
  #70
TJ_Max's Avatar
very good idea. Thanks, will do tonight.
Old Apr 20, 2006 | 10:33 AM
  #71
C MAX's Avatar
yeh you better clearcoat it so after i bust your a$$ the salt from your tears wont rust it,lol.just let me know when yor monster is ready,lol.
Old Apr 20, 2006 | 10:34 AM
  #72
TJ_Max's Avatar
BTW, the most cost efficient way to do this is FMIC is get the place racing style intake from ebay for $24 shipped for the TB connection to the fender, then couple up the BOV flanged pipe there after a 45 degree bend toward the front of the car? Slammed can you give us a list of the bends, piping from TB to cooler, then cooler to blower? IE, place racing to 45 degree elbow to straight coupler, to straight bov pipe, to 45 degree bend to IC.... Or how much would I get charged to have this made for me?
Old Apr 20, 2006 | 10:35 AM
  #73
TJ_Max's Avatar
Old Apr 21, 2006 | 03:13 AM
  #74
JAY25's Avatar
Get a T trim so you can get 10 PSI from a 3.125. That will spin you up to min 13 PSI no intercooler.
Old Apr 21, 2006 | 05:00 AM
  #75
Blu's Avatar
Blu
the tits
and the T-trim will not have to work as hard to built the boost and push it through the IC. Its a lot beefier head unit....
Old Apr 21, 2006 | 07:28 AM
  #76
TJ_Max's Avatar
Now, how much was the "upgrade" program? Looks like they are talking about giving only like $1,000 credit when you exchange your blower. WTFz.
Old Apr 21, 2006 | 07:52 AM
  #77
Blu's Avatar
Blu
the tits
It costs right at 1k for them to rebuild a V1 S-trim to a V1 T-trim spec. There is no exchanges the guts are replaced as well as the larger impellar and opening.
Old Apr 21, 2006 | 07:56 AM
  #78
TJ_Max's Avatar
And v2 guys are just plain and simply put, SCREWED? :sigh:
Old Apr 21, 2006 | 09:40 AM
  #79
ewuzh's Avatar
You can just buy a V1 blower off ebay, send that in, and sell your V2. I did the opposite of that (V1 --> V2 blower).
Old Apr 21, 2006 | 09:50 AM
  #80
TJ_Max's Avatar
Damn, you had the upgrade option right there in your hands! Dammit, anyone wanna trade?
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
Johnny9595
Sep 3, 2015 05:18 AM
