belt # for 2.62 pulley?
Old May 28, 2006 | 02:12 PM
chris'smax's Avatar
I decided i am gong to go ahead and put on my 2.62 pulley on my blower, but i can't find the belt # that goes w/ this pulley. I was thinking i could use the same belt as i did for the 2,87 since i had plenty of room to crank down on it more with the tensioner. I just want to make sure i have the right belt before i put this damn thing on next time.
I plan on using a EBC to control peak boost so no worries about the peak boost
Old May 30, 2006 | 01:24 PM
ptatohed's Avatar
Licensed to Spell
I would suspect you'll be fine with the GatorBack 4060695. That's what I am using with my 2.87". But you may need the 4060690. Just do a quick test fit with the 2.87" belt you already have (just 2-3 bolts holding the Vortech to the bracket and 2-3 bolts holding the sc to the car, route the belt).
But be careful, with my 2.87", the belt almost rubs itself just left of the pulley without siderails. You may need a smaller pulley without siderails to make sure it clears.
Use an inter/after cooler to reduce boost temps and to reduce peak boost.
Old May 30, 2006 | 01:37 PM
chris'smax's Avatar
yea i already have a custom intercooler setup+water alcohol injection. I think i am going to use the 4060690 and see if it works.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
02PearlSE
Feb 1, 2016 12:37 AM
homewrecker
Sep 24, 2015 07:01 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
