In the middle of installing my lightened crank pulley, a few questions...
Old Jun 21, 2006 | 10:26 PM
ptatohed's Avatar
Licensed to Spell
The Wizard and I tried the trick of shoving something in the flywheel teeth to stop the flywheel from turning but the crank bolt was still too tuff to undo (and I don't feel overly comfortable wedging a screwdriver in my flywheel teeth). So.... we did the (scary but effective) trick of putting the breaker bar over the crank pulley bolt and start the engine. It worked. But my question is how should we tighten the crank pulley bolt after installing the new crank pulley?
Also, we loosened both bolts on the power steering pulley and we still do not have any slack to remove the PS belt. What are we missing?
Thanks.
- Josh
Old Jun 22, 2006 | 03:16 AM
JeEvE's Avatar
If you lower the driver's side wheel to the ground and put it in gear, it shouldnt spin. Then you can just tighten it with the breaker bar.
Old Jun 22, 2006 | 01:00 PM
LatinMax's Avatar
on the PS there is a third bolt that is the pivit point that is what is causing you problems... if it is like the 5th gen.
Old Jun 22, 2006 | 11:00 PM
ptatohed's Avatar
Licensed to Spell
:o)
Thanks. But I have an auto.
Ahhhh.... thanks. I'll look for the 3rd bolt.
Old Jun 23, 2006 | 07:30 AM
I already told you about the third bolt Taterboy. Let's finish installing that pulley asap. Anything for 1 HP, right!
Let's hope my install goes smoother.
Old Jun 28, 2006 | 09:57 PM
ptatohed's Avatar
Licensed to Spell
Job done.
Butt dyno? 0 'virtual' HP
Real HP? 1-3 (guestimate)
Sleep-better-at-night factor: 4 out of 10.
Weight savings? What would you say Jim, 2 lb?
Looks? Purty.
Install difficulty? 2.5 - 3 wrenches out of 5 (1 being a FSTB, 5 being an SC).
Worth 6 hours of pay? Hmmm.... not sure about that. Ahh, heck, sure, why not?
Thanks Wizard for your help.
mvm062
Nov 30, 2020 09:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
rnb754
Sep 14, 2015 11:39 PM
crazyespn
Sep 3, 2015 01:30 PM
