Boosting a Auto
Old Jul 12, 2006 | 06:38 PM
siren001's Avatar
Boosting a Auto
Hey, I was looking at all the turbo spec and stuff, and I Was wondering what is needed different to boost a auto instead of a manual. all the sites say manual only.
Old Jul 12, 2006 | 07:07 PM
sciff5's Avatar
You would need a built tranny. Level 10 and NRH build the auto trannies but from everything I've heard NRH transmissions in maryland are the only game in town when it comes to reliable high performance auto trannies for the maxima
Old Jul 12, 2006 | 07:08 PM
killerVQ30DE's Avatar
i've 'heard' that you should get a VBmod(Valve body), trans cooler and high stall converter - I think the consensus is that nitrous/turbos dump to much power in one go so shorten lift of tranny considerably.
Old Jul 13, 2006 | 06:52 AM
SPiG's Avatar
SomePsychoGuy
There are a few people who have made the auto last SCed (Chris'sMax and Latinmax are two examples) and Jime has put a lot of power with Nitrous on autos, but no one has had a turbo auto last very long at least in stock form.
VB and trans cooler would be very crucial if you wanted it to last, but you would probably have to end up building it.
Old Jul 13, 2006 | 08:32 AM
grey99max's Avatar
LandShark has Cosworth
Well, my stock VLSD automatic has handled 2 seasons of 125-shot runs, and a few 150-shots as well, and it's still working fine - so far. Frankly, my opinion is that it's cheaper to go-till-you-blow with automatics. A few hundred bucks each makes replacing easier to swallow.
I have always used Mobil1 and a good oil cooler - I still have the original non-VLSD tranny, which worked fine when I took it out and put in the Infiniti VLSD unit. (launches got much faster with BOTH tires pulling).
Just my 2-cents worth.
Old Jul 13, 2006 | 11:47 AM
siren001's Avatar
is there a certain type or they make one for the maxima?
I gonna convert it but not for like a year, so i just want to trubo and build up what i get.
Whats the websites?
Old Jul 13, 2006 | 12:31 PM
LatinMax's Avatar
I went thru 3 factory trannies (except for the VB mod, tranny cooler & Amsoil) before I went with the NRH setup.
I kept on killing 3 and/or 4th gears from the boost.
Turbo will do the same damage as the SC. The tranny does not like shifting under boost.
The only way to go is with a built tranny. I have not heard many good things about Level 10, so I went with NRH.
Old Jul 13, 2006 | 04:03 PM
siren001's Avatar
Did you have to send your tranny to NRH or they already have ones built? How much did it cost you.
Old Jul 13, 2006 | 08:24 PM
LatinMax's Avatar
It runs around $2500-3000 and you have to send them your tranny.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
BobTX10
Oct 7, 2015 08:43 AM
MichMaxFan
Sep 30, 2015 09:18 AM
