Supercharger install- Alternator rotation
Old Sep 23, 2006 | 02:42 PM
RichMax's Avatar
Boosted like Snipes tax refund
How did you guys rotate the alternator per the instructions so that the mounting plate bolts would line up?
Old Sep 24, 2006 | 06:48 AM
matty's Avatar
push it up or down, after you take the top mount off the alternator.....
Old Sep 24, 2006 | 11:57 AM
ptatohed's Avatar
Licensed to Spell
Read my write-up. Use a long, skinny screwdriver to judge how close you are and use a hammer to tap the alternater in the appropriate direction.
Old Sep 25, 2006 | 08:01 AM
IIRC, Stillen instructions tell you to loosen the hard to get to bolt (behind the alternator) which secures the alternator to the engine. I would like to add, that you should try Matty's and Ptatohed's tips w/o attempting to loosen the hard to get to bolt. That should be plan C.
Old Sep 27, 2006 | 04:53 AM
RichMax's Avatar
This hard to-get-to bolt... would I need to move the compressor to get it? If not, what would I need to access it?
Damned alternator won't budge at all...
Old Sep 27, 2006 | 07:05 AM
Nah, you don't need to move anything. IIRC, all you need are some long extensions, a flex elbow, the correct socket and some patience will do the trick. You'll have to stick your head up into a cavity to see, then the rest is done by feel with your hands. It's a real PITA, but doable.
TallTom
57
Oct 14, 2025 05:16 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
