What did you guys use...
Old Dec 10, 2006 | 07:39 AM
RichMax's Avatar
Boosted like Snipes tax refund
what did you guys use to keep the Intake Air Temp sensor in place while your rtv/silicone sealant set and cured? Don't think I can hold it in place 24 hours
Old Dec 10, 2006 | 07:46 AM
Kevlo911's Avatar
Kevlo for President
Where are you putting it? Why arent you using the rubber grommet?
Old Dec 10, 2006 | 09:03 AM
RichMax's Avatar
I do (I think) have the rubber grommet in my elbow. However, in doing a smoke test for vacuum leaks, I found the IAT sensor wasn't securely in the elbow, so it was letting air leach out AFTER the MAFS. I found that by applying pressure to push the IAT into the elbow while sending smoke through the elbow, I could reduce the amount of air leakage.
To eliminate this air gap, I am going to pull it out of the elbow, apply rtv sealant, and stick it back in the elbow. I was asking this question because I wanted to know how people applied pressure to keep it in place while the sealant sets (it aint exactly 2 flat surfaces against one another...).
Any other ideas for making sure air isn't just leaking out of that hole? I DEFINITELY have an air gap there right now...
Old Dec 10, 2006 | 01:53 PM
trialt's Avatar
mine came with 2 small screws on each side of the sensor to hold it in..
Old Dec 10, 2006 | 03:01 PM
matty's Avatar
I also have two screws with a plate on the inside to hole it on. I beleive I used a bit of a sealant when I originally put it on.
-matt
Old Dec 11, 2006 | 08:24 AM
RM, something is wrong, because it's a simple bolt up/plug and play application. No sealant necessary. Sounds like you're missing parts.
I<3 A32's
Sep 10, 2015 11:07 AM
dcam0326
Sep 7, 2015 07:26 AM
Max139617
Sep 6, 2015 06:02 PM
nbstriker10
Sep 4, 2015 04:26 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
