looking to put together an intercooler kit
Old Jan 29, 2007 | 06:11 PM
absoundlab
hello everyone I have a 2000 nissan maxima 3.0L 5sp.
Im looking to buying a kit from matty and getting a v2 and putting the kit together myself. I'm working about the intercooler. I want to run 3 inch piping to a front mount intercooler. If I use an intercooler thats say 29x9x3 would I have to leave the front bumper reinforcement out? Instead of buying all the bents seperate could I buy one of these kit? I know non of these kits on ebay are make to be a direct bolt on to the maxima. But im thinkin I could buy one of these kits and just the piping from it and cut it to fit. Would this be a good idea?
http://cgi.ebay.com/ebaymotors/3-Int...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/Altim...spagenameZWDVW
also whats a good intercooler that I can buy on ebay?
mods I know I posted this in the wrong place can you move it for me thank you.
Old Jan 29, 2007 | 10:36 PM
Selecting the right size intercooler is not as easy as it seems. Just because it fits, doesn't mean your research is over. There are so many factors when choosing an intercooler, and knowing your current power level and power goals play a role too. Are you basing you decision on what fits? Or on all the many variables? IMO, there are too many unknowns at this point.
Also, why do even want an intercooler? Just for looks? You do realize that when adding an intercooler, your intake temperature drops (good), but at the expense of lost boost (bad). Stephen Max, one of the godfathers here, put on an intercooler and netted no hp gain, proven by a dyno. He pretty much broke even. However, his intake temp is lower which is a good thing I guess. Put on the wrong size intercooler and you could actually lose HP. See where I'm going here?
BTW, the "complete" kit on ebay has $hitty couplers and cheesy worm clamps that won't hold the test of time. Besides, do you have the routing of the piping figured out? Are you using mandrel bent pipes at the various bends, or silicone couplers? IMO, I'd come up with a plan of attack and order exactly what you need from intakehoses.com.
First things first, get Matty's kit and piece the rest together. Install everything and make sure all is running good. Then come back and we'll talk intercoolers.
I apologize in advance if I come across as a jerk, that is not my intent. I'm just trying to steer you in the right direction.
Old Jan 30, 2007 | 07:54 AM
absoundlab
wizard you didnt come across as a jerk, not at all. thank you for the info. my goal is to use mattys kit with a v2 and im sparying zex wet 75.
I want to intercool the v2 one for the look and two for the lower intake temps. because down south over here it gets hot outside most of the year.
also im thinking about buying this piping kit on ebay because they have most of the pipes that I need all in one package. (I know its not a direct bolt on or anything like that for the app that im using.) And I do plan on changing the couplers and clamps.
Old Jan 30, 2007 | 08:34 AM
Ok. You may want to consider dropping pulley sizes to make up for the lost boost.
Also, I purchased this book per the recommendation of others... It's great so far, I'm only half way through (even though I bought it 6 months ago) Lots of good info about how to properly size the right intercooler for any application.
http://www.amazon.com/Supercharged-T...e=UTF8&s=books
Old Jan 30, 2007 | 08:37 AM
Oh, and this one too! Only $7.49 used!
http://www.amazon.com/Street-Turboch...399795-7198263
New release for 2006.
Old Jan 30, 2007 | 09:27 AM
absoundlab
alright cool I'm going to buy both of them.
what I had in mind was matty's plate
v2
vortech fmu
walbro 255 hp
300zx maf
300zx injectors
3 inch exhaust
electronic cutout
blow off value
tranny cooler
oil cooler
boost gauge egt gauge
3 inch intercooler piping
hump silicone clamps
aquamist water injection
all of that along with the zex wet 75 shot that I have right now with
msd window switch 3000 and 6500 pills
fuel pressure safty switch
msd sport compact sci digital
tank gauge
bottle heater
purge kit
apexi vafc-II
berk intake
headers and y pipe
no cat and no resonator
short shifter
Old Jan 30, 2007 | 05:42 PM
Damn, that's a tall order. I hope you're planning to do that in stages. Doing it all at once will be a troubleshooting nightmare.......
Old Jan 30, 2007 | 06:12 PM
absoundlab
I have all the n20 stuff and nothing for the s/c yet
Old Jan 31, 2007 | 12:14 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
James, what are you doing giving advice like that? Just kidding man. Adsoundlab, I was wondering if you had an idea of what you wanted to do.
www.intakehoses.com is definitely the way to go.
Old Jan 31, 2007 | 06:29 AM
absoundlab
what do you mean if I have an idea of what I want to do? like with the s/c?
Old Jan 31, 2007 | 08:55 AM
Flava_24/7's Avatar
Boosted Panda
No crap.
Best bet would be to get the SC on and running with a good tune. Then slowly bring on the other goodies.
I hope your planning on some down time, could take some to get everything dialed in with the water injection and the NOS. Piecing together the intercooler could also result in some downtime, I know it did for me and as The Wizard stated, the end result was bad, I lost major boost by going with an intercooler that was too small for my setup. I have since removed the intercooler and just ran a straight pipe in its place, like Stephen Max's old setup.
Old Jan 31, 2007 | 11:20 AM
i30ds's Avatar
Armed and Dangerous
I would definately tackle that list in stages.
Get the ebay kit you listed for the piping as it has all the bends you need. Like Wizard said, you might want to get different couplings and clamps though...
Good luck.
Old Jan 31, 2007 | 12:16 PM
slimer's Avatar
Good luck.
Thats what I'm talkin bout.
Old Feb 7, 2007 | 02:49 PM
i30ds's Avatar
Armed and Dangerous
I have both these books and I highly recommend them as well. Knowledge is food for the brain, and boost is ***** for a car... combine both to create knowledge of boost, and you'll be unstoppable.
t6378tp
Sep 29, 2018 04:27 PM
BkGreen97
Apr 2, 2016 05:47 AM
crazyespn
Sep 3, 2015 01:30 PM
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
