intercooler help
Old Apr 28, 2007 | 02:25 PM
MaxObesset's Avatar
intercooler help
a friend of mine wants to intercool his 98 supercharged max but he wants to keep the stock foglights can anybody help him out i also might intercool but not yet though
Old Apr 28, 2007 | 11:31 PM
maxgtr2000's Avatar
KH3 by popular demand
I know it has been done but I think you have to use 90 degree elbows going straight back.
Old Apr 29, 2007 | 06:21 AM
Kevlo911's Avatar
Kevlo for President
Maybe he get get one of those skinny intercoolers?
Old Apr 29, 2007 | 08:02 AM
MaxObesset's Avatar
or do you think the intercooler is even worth it on a supercharged max?
Old Apr 29, 2007 | 08:22 AM
Kevlo911's Avatar
Kevlo for President
I don't, I just run a "cai" on it. How much boost is he running?
Old Apr 29, 2007 | 08:30 AM
Tatanko's Avatar
Bacon Lover
I would say 3" charge piping is worth it, but an air-to-air intercooler wouldn't be. Seems like anyone here who has tried one has gotten benefits of lowered charge temps, but also dropped enough pressure to balance out the gains and end up at square-one. I don't know much about the air-to-water, though.
Old Apr 29, 2007 | 08:52 AM
MaxObesset's Avatar
he's running 11 psi but he's going to do the 3.5 swap and be running the same he just wants to find out if he would need to intercool the car or not
Old Apr 29, 2007 | 08:57 AM
Nealoc187's Avatar
SLOW
I'd just run the charge pipe across the front first and see if that is sufficient. I bet it will be with the retarded timing of the 3.5 with 3.0 ECU, etc.
Old Apr 29, 2007 | 09:00 AM
MaxObesset's Avatar
yea hes going to retard the timing
Old Apr 30, 2007 | 09:57 AM
TJ_Max's Avatar
Paradox Systems Vendor
11psi on the 3.5 motor? He should start at the lowest boost level and work from there IMO. You're going to lose boost through that intercooler piping though. If it is the best intercooler piping in the world, you may still lose 1psi. Back to your original question though. I believe 6inches is the tallest without cutting the bumper support. The SC outlet is 2.75", so it would be best if you can get an IC with that inlet/outlet diameter and run 2.75" piping straight through. Avoid bottlenecking the boost going into the IC (ie 2.75" piping reduced to 2,5" at the inlet of the IC). I think anything under 30" long, end tank to end tank will allow you to keep your fogs with bends going straight back as mentioned above.
Old Apr 30, 2007 | 11:56 AM
absoundlab
I think you are going to have to get rid of the fog lights in order to use a fmi
Old Apr 30, 2007 | 01:43 PM
MaxObesset's Avatar
he said hes gonna try without intercooler and see how it goes from there
Old Apr 30, 2007 | 02:08 PM
mforrest100's Avatar
Ummm...lets take a step back....with my car now and before I sold my Supercharger....when I looked at the engine bay with the 3.5, there was no room to run cross piping. So I was going to intercool because I had too basically. Maybe its just be...but these not seem so be room for 3" piping.
Old Apr 30, 2007 | 02:34 PM
Tatanko's Avatar
Bacon Lover
The 3.5 doesn't take up any extra room
Old Apr 30, 2007 | 04:02 PM
98MaXeDouT's Avatar
Yea I have PLENTY of room for a charge pipe??
Old Apr 30, 2007 | 04:49 PM
MaxObesset's Avatar
hmm yea i think you do lol
Old May 2, 2007 | 10:29 AM
TJ_Max's Avatar
For the record, intercoolers come in different sizes. He would have to get rid of the fog lights to use THAT FMIC.
Old May 2, 2007 | 11:20 AM
You guys have plenty of room for the stock charge pipe or 3" charge pipe? Additionally, is this with the cover on or off? I am speaking in terms of with the cover on.
From these pictures you can't tell me that a charge pipe will go across. And then the BOV will have to clear. Just me...but I would rather run the intercooler than remove my cover. I know..I am weird. But without the cover...I guess it can be done.
t6378tp
Sep 29, 2018 04:27 PM
Cotozic
Jun 28, 2017 08:01 PM
BkGreen97
Apr 2, 2016 05:47 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
