still need some advice on timing
this time im trying to figure out the timing and was told 2 different things. zero told me to set timing to about -7@peak power and work progressively down both sides. the guy at a shop told me to retard -1 degree for evry psi of boost at the rpm. so since my peak boost and power should be 15psi at almost redline do I retard -15 at redline and work progressively down backwards? it seems that the -7 degree timing retard is not enough as I still get detonation. well, I will try the -15 and work down tomorrow. any input would be helpful though with guys that use 2.62 pulley and emanage for timing.
where do i get the lc1 for $175????
Ask for Marty
888-465-7373
www.InjectedPerformance.com
Enginepartswarehouse.com
Xenocron.com
http://cgi.ebay.com/ebaymotors/Innov...spagenameZWDVW
You don';t need the dyno to tell you how much timing you can run unless you're running race gas. On pump gas, you will always be limited by detonation threshold. You will not exceed MBT on pump gas, no way. Spend money on an accurate AFR measuring device and set your timing based on knock tendencies. It's probably a good idea to get a knock sensing device like knock lite to tell you when you're inducing detonation.
carlosvq30
Aug 17, 2015 11:32 AM
