smoke from pcv!!
smoke from pcv!!
just wondering what this means?? I have white smoke coming out from both valve cover pcv openings. what is this the symptoms of, how serious is it, and how do i fix it? I changed the oil and theres no coolant in it and theres no oil in the coolant so I dont think its a head gasket.. also theres no smoke coming from the exhaust..
Originally Posted by trialt
my pcv is vented because I have a s/c
Are you sure you have your terminology correct?
Now, if you're talking about the crank case breather hose, just to the right of the spark plug cover, then yes some people put a baby K&N filter on there rather than recirculating it back into the air stream.
Please clarify.
How many miles does ur engine havE?
Did you just get done driving that car really hard ??
I drive my car pretty hard and NEVER had this problem. Smoke from your engine bay isnt a good thing by any means
-matt
-matt
no i havent driven it hard lately.. just started running crappy and started smoking on my way to work.. im pretty sure there is some type of compression leak though.. aka ring lands.. so i guess thats the end of my maxima project. not really down to invest the money into it..
Originally Posted by matty
Quit saying you "blew your pistons" all around the Forum. You didnt blow your motor....Do a Compression Test. That will tell the entire truth.
-matt
-matt
-matt
-matt
bye bye to that 400whp goal
ballerchris510
Sep 10, 2015 09:35 PM
