Independant oil reservoir
Old Aug 16, 2007 | 11:47 PM
97maximaman's Avatar
I've been thinking about this the past couple days while still planning my rear mount turbo. I just cant figure out why no one has done it. I'm thinking, mount a separate oil reservoir in the trunk, with an oil pump to serve the turbo. it would be closer to the turbo and would not rely on the engine oil. It just seems to easy, why hasn't anyone done it? I can either weld together a metal oil reservoir or use a jegs fuel cell? Any recommendations on oil pumps to use for this type of job. Only reason i thought this up is because i dont like the idea of tapping into the main oil supply, leak=no more engine. Not a good plan, my way=only the turbo would blow.
Old Aug 17, 2007 | 11:53 AM
SPiG's Avatar
SomePsychoGuy
For the trouble you are talking about, you should just convert to dry sump. Or you could just mount the turbo up front and not have to worry about it.
Old Aug 17, 2007 | 03:03 PM
Dry sump? Dont know what that is. And this way would be cheaper than mounting upfront. I was thinking a scavenge pump like streatzlegend, but hooked to a oil reservoir.
Old Aug 17, 2007 | 04:04 PM
SPiG's Avatar
SomePsychoGuy
http://auto.howstuffworks.com/question331.htm
It is basically what you described with the separate oil sump and pump, but for the engine.
I still don't understand the whole, I want to skate up hill and reinvent the wheel vs. improving what is tried and true mentality.
Old Aug 17, 2007 | 04:54 PM
I see what your saying now, its more expensive and complex with 2 pumps. Wasnt trying to reinvent the wheel, im new to to forced induction so i've got alot of questions and posts to come, please bare with me. I'll have to check with streetzlegend to get more info on how he did his so well.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
