new turbo set up Tell me what you think of it.
Old Aug 19, 2007 | 05:31 PM
95turbo gxe's Avatar
WEll first off I can not weld pretty and I probley over weld just to be sure that its seals. The pipes are 2ich to 2.25 for the feed. The back manifold is a modded det manifold and the front is a modded 4th gen manifold. They are equal lenth feed pipes with in a inch. The down pipe is 3ich. I dont have anymore pipes going under the car so no more ground clearence porblems. All the pipes will be heat wraped.
Old Aug 19, 2007 | 06:12 PM
stephenlc's Avatar
looks good man.
Old Aug 19, 2007 | 08:15 PM
EnervinE's Avatar
i has college
Hah you aren't kidding about the welds. Looks good.
Old Aug 19, 2007 | 08:28 PM
Kevlo911's Avatar
Kevlo for President
More pics pleaseeee
Old Aug 19, 2007 | 09:32 PM
ill get some more pic tommorow of it just about complete.
Old Aug 19, 2007 | 10:19 PM
95BLKMAX's Avatar
sweeeet! keep the coming this way!
Old Aug 20, 2007 | 04:19 AM
Add some more photos at the top. Still need to clean the set up a little more with some heat wrap and cleaning
Old Aug 20, 2007 | 06:02 AM
Kevlo911's Avatar
Kevlo for President
I would try to move the maf closer to the fender so it isn't so close to the feed pipe.
Old Aug 20, 2007 | 07:18 AM
maxine'sMan's Avatar
I can't see if you are using anything aside from the feed to support the turbo. Is it mounted to anything else? I noticed that you have those little flex pices so I would imagine it was in your plans to do so at some point.
Old Aug 20, 2007 | 09:38 AM
Yes part of the feed rest on the tranny and right under the turbo its braced to the tranny with a brace.
Old Aug 21, 2007 | 09:16 AM
liqidvenom's Avatar
brotherhood of tq
very nice...maybe your car can hold together so i can see it at the next maximus....lol
Old Aug 21, 2007 | 09:43 AM
Tatanko's Avatar
Bacon Lover
That's the downpipe. You're slipping Kev
Just joshing. I'm bored and that was easy to pick up on
Old Aug 22, 2007 | 06:53 AM
AllBlackMax's Avatar
aka The Doom Ship
Not exactly a "hood opener" type of setup but I give you credit for your work.
Old Aug 22, 2007 | 07:51 AM
mtcookson's Avatar
Holset FTW!
Did you get your clutch issue worked out?
Old Aug 22, 2007 | 01:41 PM
You will when I get done. Had to get it working first then I said I would clean it up some.
Mark It was A broken axels
Old Aug 23, 2007 | 05:39 PM
dfownz's Avatar
What type of welder are you using?
DF
Old Aug 24, 2007 | 04:54 AM
DF
Lincon 140 wire fed.
Update I been riding around and this set up shows a maf V gain of .24 Over my old set up with the forward y pipe at 1 psi less.The maf has not been moved its in the same place. Spool time increase about 300 rpms. At 9 psi 1 st gear is ok till you hit about 5000 and second is useless in the streets. If you start from a roll in second after you hit 4500 it just goes to spinning. IM liking this turbo so far as they dont make any power at all intill you get to around 12-14 and then on up intill the 30's But it seems to be making some good power at 9 psi on the vq. Im plan on running about 16-18 after I get some more tires and my front end fixed
Old Aug 24, 2007 | 12:43 PM
JeEvE's Avatar
Cool setup, good to hear that it is working well. I was thinking about doing something similar but the space seemed very tight...looks like you have no ABS?
I was helping a friend out on a turbo setup on his Regal GS, its basically setup exactly the same but we made new manifolds so they face directly toward the driver side and straight into the turbine.
Old Aug 24, 2007 | 01:13 PM
Tatanko's Avatar
Bacon Lover
Is your friend on ClubGP? What's his name, just curious. I'm in the w-body crowd in a way since I know SO many people that have them. I also have a buddy with a turbo Regal.
Old Aug 25, 2007 | 02:25 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
If you ever have to take the manifolds off....... how will you do it ? Cut it off and then reweld it back on ? Looks like you overlooked that step.
Old Aug 25, 2007 | 03:47 PM
Onside is flange one side has a flex so it will come off
Old Aug 25, 2007 | 03:49 PM
nismology's Avatar
I read "equal length" and went O_O!
I'd really like to hear this setup.
Old Aug 25, 2007 | 03:54 PM
Wouldn't OEM or any aftermarket shorty headers for a RWD VQ like a 350Z work better ? I was thinking of doing something similar to my car using those manifolds.... but Neals setup is stuck in my head the whole time, if I could only retain the AC
Old Aug 25, 2007 | 06:13 PM
The det manifold works great. Other manfolds would drop down to far in the back and piping would be and issue in the rear. Now the front is ok but I took a stock manifold and made it go like I wanted it
Nismolgy Im not sure what your saying about wantingto hear this set up?
Old Aug 25, 2007 | 06:35 PM
dfownz's Avatar
10 bucks says its because its equal length.
Very nice set up. Can't wait til I can afford something like this.
DF
Old Aug 25, 2007 | 06:47 PM
DF
WEll their are close with in a inch or so of being equal
Old Aug 26, 2007 | 06:24 AM
JeEvE's Avatar
His name on ClubGP is speeder2000. The car still needs a lot of small things done, the hard stuff, the manifolds/downpipe is basically all done and it turned out great. Ill see if I can find the pics and ill post em up.
Matt93SE
May 24, 2019 02:58 PM
Matt93SE
Apr 8, 2018 09:23 AM
Cotozic
Jun 28, 2017 08:01 PM
homeyclaus
Sep 3, 2015 06:15 PM
max_speed97
Aug 26, 2015 07:46 PM
