Rich or Lean Condition ??
Old Aug 21, 2007 | 06:59 AM
matty's Avatar
When you first started your boosted vehicle and the idle dropps really low and almost dies, then idles really funky up and down (up and down up and down) till it settles out, is that a lean condition, or a rich condition ?? Or maybe its a Vac leak ?? Im trying to figured out a problem that im having. Once its started and running for more than 10 seconds, its fine. I thinking rich
-matt
Old Aug 21, 2007 | 07:39 AM
98MaXeDouT's Avatar
I had the same problem....it's almost definitly fuel related. You're running an FMU correct?
Old Aug 21, 2007 | 07:55 AM
BlackCat's Avatar
RIP '98 Maxima SE
I'm getting that condition when I'm waiting at a light. The rpm is at 700 and the fuel pressure is pegged at 34psi. When the idle starts to dip to 600rpm the psi drops to 32 -30psi. This condition started to happen after my rubber fuel line popped off of the fuel rail adapter last week and it has never happened before that. Would that problem be attributed to the Walbro? Fuel filter? I've got the Aeromotive fpr and Begi fmu.
Matty, what does your temp gauge say when that happens? I'm seeing a drop from 800 down to 750 on my gauge.
Old Aug 21, 2007 | 10:27 AM
matty's Avatar
Its really only when the car is completly cold. ie: sitting over night. Once its warmed up, its perfectly fine. Start up, idles really low, then kicks up, and revs up and down. Its really weird. I remember it doing this a while ago and I cant rememeber how I fixed it. I think its BOV related because I did switch BOV's to a larger one (releasing too much air on start up and messing up idle so the IACV is trying to compinsate)
I am running: NO FMU, AEM FPR set at 34psi, Emanage Ultimate.
Old Aug 21, 2007 | 11:11 AM
98MaXeDouT's Avatar
Hm....that happened with my Greddy BOV...it was opening and closing with idle....I changed the the Blitz...and fixed all my leaks. Idles perfect now...
Which BOV are you using now?
Old Aug 21, 2007 | 12:42 PM
BlackCat's Avatar
RIP '98 Maxima SE
I'm using the Blitz DD
Old Aug 23, 2007 | 06:55 PM
matty's Avatar
Its amazing how sensitive the car is when there is a vac leak after the MAF. The Temp sensor wasnt all the way tight and a bit of air was blowing out of there. Metered air being released it not a good thing. I added a bit of silicone around the temp sensor as well to ensure its perfect.
-matt
Old Aug 23, 2007 | 08:11 PM
98MaXeDouT's Avatar
-matt
Good to hear man...
Old Aug 23, 2007 | 08:15 PM
matty's Avatar
I will have pics of my new setup on tuesday when I get a chance to detail the car. Wait till you see
-matt
Old Aug 23, 2007 | 10:57 PM
maximariceboi's Avatar
hahah i got a nice preview of the set up =] good work man
jmlee44
Oct 2, 2022 02:13 PM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
fx4five
Oct 18, 2015 06:57 PM
