SAFCII safe tune?
Old Sep 19, 2007 | 12:56 PM
kzoosho's Avatar
SAFCII safe tune?
Since i cant access some of the links is there anyone that may be able to tell me some of the settings i will need to put a safe tune on my car to run it? I have a t3/t4 38mm wastegate set at 7psi 2.5 feed pipe and down pipe and 2.5 inch feedpipe. I do have a wb but it is not hooked up as i am waiting on the controler/ reader for it. if any one can help me i would appreciate it.
Old Sep 19, 2007 | 01:10 PM
NmexMAX's Avatar
dot dot dot ...
Get an AFR readout and take it from there.
Best/smartest thing to do is to acquire a wideband with data logging software, and if you get ambitious, maybe even an in cab readout. Then log some WOT runs and adjust accordingly.
IMO, worst thing to do is use someone else's settings.
Old Sep 19, 2007 | 01:19 PM
kzoosho's Avatar
yea i just was asking for basically first run use. i dotn want to run way lean you know. I have the reader/ controler on the way now so i can use the datalogging but for now i have to drive the car and dont want to have a very lean condition thats all.
Old Sep 19, 2007 | 07:23 PM
JeEvE's Avatar
You dont want to use anyone elses settings. My setup is street tuned with a SAFC I and an Innovate wideband which has a display gauge. I initially started by just adding fuel all across and then doing WOT pulls and then added/removing fuel. When I dynoed, it was a very flat A/F line around 11.3-5.
Old Sep 19, 2007 | 07:28 PM
kzoosho's Avatar
so basically just add fuel and i will be ok? well i will try this later as i have never tuned a car before.
Old Sep 19, 2007 | 08:23 PM
JeEvE's Avatar
Do not try to tune or go WOT without having your wideband hooked up, because you can add fuel and still be lean.
Old Sep 21, 2007 | 10:32 AM
streetzlegend's Avatar
or add too much fuel which is not good either. dont do ANYTHING untill you get a wideband man. another dude on here kept on posting about how he should have his tuned, wat corrections to put, etc..., he didnt have a wideband and we kept on telling him not to mess with anything untill he had a wideband. He ended up blowing the motor i believe. so please, just get a wideband as it will be the best investment you make for the car.
Old Sep 23, 2007 | 10:40 AM
kzoosho's Avatar
have wideband just no reader. I am waiting on it now.
Old Sep 23, 2007 | 03:46 PM
NmexMAX's Avatar
dot dot dot ...
Any way to log AFR data?
Old Sep 25, 2007 | 10:23 AM
kzoosho's Avatar
the dyno guy can wen he dynoes the car.
Old Sep 25, 2007 | 09:26 PM
NmexMAX's Avatar
dot dot dot ...
Exactly my point.
Old Sep 25, 2007 | 10:50 PM
97maximaman's Avatar
This is why your supposed to put the wideband in before the turbo, lol. Ye it sucks but dont drive it till the wideband is in. Unless of course you like making more work.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
sliptap
Sep 30, 2015 05:57 AM
Andy29
Sep 29, 2015 05:32 AM
Socalstillen
Sep 26, 2015 12:01 PM
