Gizzmo Launch Interface
Old Dec 31, 2007 | 06:37 AM
secondtonone317's Avatar
nycnissans
I know you can do this with E-manage but I dont want to really go EU.........anyone ever tried this on a VQ? I really like the idea of this because with it you can shift without coming off the gas.........keep that boost spooling and you can get a nice launch, its like 2 step........it costs about $150
http://www.apexi-usa.com/product_giz...=263&pageNum=1
Gizzmo's launch interface integrates with the Gizzmo Tach Recall Shift light to enable the fully adjustable launch control function. The launch control function induces sequential misfire events at the desired RPM set by the user.
In a turbo application, having the throttle open while inducing misfire increases the velocity and density of exhaust gases, and in doing so allows the turbo to spool up and generate boost without load. This results in boost being generated before launching, therefore allowing a vehicle to launch with considerably more power. The launch interface is activated by the engagement of the clutch and therefore allows flat shifting (the ability to change gears without removing your foot from the throttle). With the clutch engaged the RPM will pull back to the launch RPM previously set by the user in order to avoid over-revving. This allows the engine to remain in boost while moving through the gears.
Launch control can benefit naturally aspirated cars by giving a consistent launch RPM for the best result every time, and enable quicker gear changes through flat shifting.
CONCEPT:
* Fully adjustable launch control * Adaptive auto detect software * Interfaces up to 6 coil channels * Sequentially induced misfire technology
CHARACTERISTICS:
Processor: 20mhz RISC Misfire type: Sequential Case size: 55mmX45mmX10mm
__________________
Anyone have any experience with this?
Old Dec 31, 2007 | 09:32 AM
95BLKMAX's Avatar
wow that looks pretty damn cool! I'd like to know too if some1 has any input on this. Im on the same boat as you, EU not for me.
Old Dec 31, 2007 | 09:35 AM
jaemax's Avatar
I will be the guinea soon enough... lol....
Old Dec 31, 2007 | 10:05 AM
nycnissans
I deff. want to hear what the opionated folks on here has to say about this, it says you have to splice like 15 wires..........not bad if you ask me....
but one thing that I was wondering since this works by initating "sequential misfires" would it trip a CEL and throw the car into "limp mode"?
Old Dec 31, 2007 | 10:15 AM
absoundlab
thats looks pretty cool
Old Dec 31, 2007 | 12:20 PM
kzoosho's Avatar
I wouldnt mind haveing it also. I would like to have launch control when i go to the track.
Old Jan 5, 2008 | 04:42 PM
choray911's Avatar
The Crazy Azz Cracka
Sounds suspect, I'll have to look into it.
Old Jan 12, 2008 | 08:00 AM
VqMoNsTeR's Avatar
im thinking about doing this also. a little literature for u guys. http://www.gizzmoelectronics.co.uk/product_launch.htm
it has an install manual im reading up on now fwi..
Old Jan 13, 2008 | 07:16 AM
jaemax's Avatar
it appears, you will need their shift light inorder for it to work as needed.... or am I the only one getting this impression?
Old Jan 13, 2008 | 07:57 AM
nismology's Avatar
Originally Posted by choray911
Sounds suspect...
Oh yea it does. It'd be great if it worked though...
Old Jan 14, 2008 | 12:47 PM
VqMoNsTeR's Avatar
apparently. its crazy how they want u to buy that expensive light and the impression im getting is that its only used to program. it seems like it would work. for anybody interested they sell them on ebay also. im not sure what they are selling them off the site. i didn't see any prices.
Old Jan 21, 2008 | 07:31 PM
VqMoNsTeR's Avatar
has anybody seen this??
http://youtube.com/watch?v=PqNoOqVgnV0
Old Jan 21, 2008 | 07:34 PM
Merlyn's Avatar
And... I'm out
Originally Posted by VqMoNsTeR
THATS MY VIDEO :-D I was just about to post it...
Old Jan 21, 2008 | 07:35 PM
Merlyn's Avatar
And... I'm out
http://youtube.com/watch?v=CLgRQfE2inY
that is it set at a much lower RPM....
Old Jan 21, 2008 | 08:07 PM
VqMoNsTeR's Avatar
what are u using for ur 2 step?
Old Jan 21, 2008 | 08:09 PM
kzoosho's Avatar
What are you using?
Old Jan 21, 2008 | 08:34 PM
nismology's Avatar
He's using the EU per the video and his sig. Which doesn't help this thread at all...
Old Jan 23, 2008 | 11:22 PM
Maxpwer's Avatar
No turbo, no care!
This device seems like a normal "stutter box". It allows you to lower the rev limit, which just like the stock system cuts spark to various cylinders (aka misfire). This does in fact help help you spool your turbo while stopped/off the line. Nothing new here, an MSD and other aftermarket ignition system can do the same thing.
Old Jan 23, 2008 | 11:41 PM
nismology's Avatar
OEM rev-limit = fuel cut.
Old Jan 26, 2008 | 02:19 PM
ptatohed's Avatar
Licensed to Spell
I simply power-brake (at any RPM I want) to launch.... and I never have to take my foot off the gas to shift.
Old Jan 26, 2008 | 06:41 PM
kzoosho's Avatar
auto guy.
Keven97SE
Dec 6, 2000 01:45 PM
JimW
Nov 20, 2000 05:57 AM
ZuMBLe
Nov 19, 2000 04:58 PM
ZuMBLe
Nov 17, 2000 12:20 AM
