Emanage Blue Question
Old Jul 25, 2008 | 08:51 AM
kzoosho's Avatar
Ok well i have searched and searched but i cant find out why the emanage says to tap the injector wires and not intercept them. Am i going to be doing it right just tapping them or do i need to intercept. Also does any one know the pins to use? All i keep coming up with is ultimate wiring. Any help would be great i would like to get this thing tuned better.
Old Jul 25, 2008 | 11:49 AM
DandyMax's Avatar
3.5 in the works
The reason they're tapped and not intercepted is because the EB can't remove fuel directly using the injector lines, it can only add fuel by extending the pulse time. To take out fuel the airflow map must be used.
Which pins are you talking about, on the EB or on the ECU? Because the ECU injector pins are the same.
Old Jul 25, 2008 | 11:52 AM
kzoosho's Avatar
EB but i think you answered what i needed so i can search more and find the rest out. Thanks Dandy. Im still trying beat your e/t and im boosted lol. Thanks a ton for the info.
Old Jul 25, 2008 | 02:14 PM
MDeezy's Avatar
just curious are diodes still needed for the EB on the 4gs? always heard mixed answers, melted coil packs, some not. never knew a solid answer.
Old Jul 25, 2008 | 11:00 PM
DandyMax's Avatar
3.5 in the works
For what it costs I'd put them in.
Old Jul 25, 2008 | 11:25 PM
maxgtr2000's Avatar
KH3 by popular demand
I think the latest blue update was supposed to fix it but I would run diodes to be safe. I had the ignition harness but a pin got damaged when I was installing it and the weak connection caused the car to misfire but I had diodes on mine. The way to test it is to run the car with the a/c on and feel the coil packs, if they are getting warm then you need diodes. According to this I think it was version 1.36 firmware that had the fix. Firmware Upgrade fix list.
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
sliptap
Sep 30, 2015 05:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
