Opinions on this turbo:
Old Oct 22, 2008 | 05:45 PM
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
I picked it up barely used off a friend for a steal, but I'm a total noob when it comes to what size I'm looking for.
It's a t3/t4 A/R .63 turbine, compressor A/R .60. Not sure if any other info is needed off this.
I know it's a pretty small turbo, but should this be ok on a 3.5 for the mid 300-400 whp range with a early spool?
Old Oct 22, 2008 | 06:51 PM
maxine'sMan's Avatar
yeah, sounds perfect, not sure you'll get "early spool" but it def won't be too late!
Old Oct 22, 2008 | 11:07 PM
96blkonblkse's Avatar
thats about the average sized T3/T4 hybrid size for a maxima. I think 400WHP would be kinda pushing it for this turbo. Mid 300's should be fine though! What wheel is inside there? Determining what kinda power/spoool is kinda a guessing game without knowing those two facts.
Old Oct 22, 2008 | 11:35 PM
jkpgt96's Avatar
you should be okay. there are people making very near 400 whp on the mazda 2.5 v6 with this sized hybrid..and they are starting with 90 less bhp..
Old Oct 23, 2008 | 01:04 AM
MaxBoost925's Avatar
Drug Money
Thats a good size turbo.
I had very similar specs, spools quickly and pulls like a ****.
Old Oct 23, 2008 | 12:47 PM
Nealoc187's Avatar
SLOW
I don't know if you guys are psychic or seeing something I'm not or what, but the OP hasn't provided the one piece of info that is most relevant to his question - what wheel is in this turbo. No one can make a determination one way or the other as to the appropriateness of this turbo without knowing what wheel it has. the wheel is way more important than the ARs are. AR means virtually nothing with regards to power potential.
Old Oct 23, 2008 | 12:59 PM
Ok good info. Is there an easy way to tell what wheel?
Old Oct 24, 2008 | 12:12 PM
Nealoc187's Avatar
SLOW
You can take the housing off and measure the wheel and check those measurements against known wheel sizes and figure out which one it is. Other than that your friend *should* know what turbo he purchased or his invoice for the turbo would say I imagine.
Old Oct 24, 2008 | 12:51 PM
ok got 56 trim on the turbine, still haven't taken apart the compressor housing
Old Oct 24, 2008 | 03:25 PM
nwell2k3's Avatar
Here a little info I found about turbos
From nicoclub.com
http://forums.nicoclub.com/zerothread/226519
This is what turbo wheel look like
Old Oct 24, 2008 | 04:02 PM
Cool, yeah I was reading up on some more advanced stuff too. It's pretty interesting. I need to take this compressor out and see what wheel it has, but it's a t4 and .60 a/r, and ran some 450 whp numbers on a tacoma 2.4l, so I'm hoping it'll be enough. lol
Old Oct 24, 2008 | 07:43 PM
Nealoc187's Avatar
SLOW
if it made 450whp on a 2.4L then it'll probably be just fine making 400ish on your 3.5.
Old Oct 24, 2008 | 08:14 PM
cool. If I really had to I'd lower the redline so it stays in an efficient range.
REDinLV
Aug 15, 2024 12:30 AM
dvcamp
Sep 18, 2015 10:17 AM
ac max 92
Sep 17, 2015 07:35 AM
