another supercharged 95 max!!
#41
well i had all the vac lines teed off and it was a mess now i cleaned it all up...i actually am running 1 vac line now to the fmu from the top of the 5th gen tb that little nipple behind the throttle plate...and the dyno run i have is just hp a tq no af
#42
So what FP are you reading at WOT?
#43
I lean up top and I have the vortech FMU and DEK injectors. But I am running the 2.87 pulley with VAFC adding all fuel after the VI opens up but before with teh 3.6 pulley I had to pull fuel because I was hella rich up top. Try with the vortech FMU and try getting a wideband it will save you a motor.
#44
as soon as i hit like 5 grand the fp wont go any higher then 60 psi and it starts leaning like crazy...and if u didnt read the posts maxima92 i already mentioned i HAVE a wideband 02..how else would i know i am running lean
litch
123
01-04-2024 07:01 PM
04-16-2020 05:15 AM
magiconthetire
10-26-2015 09:03 PM
maxima297
09-30-2015 03:32 PM
