Kevlo RMT Turbo build -Works !!
Old Feb 9, 2010 | 03:52 AM
  #361
t6378tp's Avatar
Turbo 3.5
Originally Posted by 93altima
what were your numbers?
I am guessing they were not that good or he did not go
Old Feb 9, 2010 | 07:11 AM
  #362
Kevlo911's Avatar
Kevlo for President
Ended up partying
Next 2 weeks = school lol. 5 tests + 5HW + 1Labreport
Old Feb 14, 2010 | 12:19 PM
  #363
VQ'ed's Avatar
SO, kevlo, if you sum it all up, what would've done differently from how it was when you put up the kit?? Different size turbo, different pump??
I started to gather up my parts to get myself a rmt on my 4th gen and I looked up on you for inspiration. Im also searching for streetzlegend threads on his rmt buildup for pictures and explanations.
Old Feb 14, 2010 | 01:09 PM
  #364
Kevlo911's Avatar
Kevlo for President
Do NOT cheap out from the get go. Make sure you get a goodturbo and a good pump. Do not get cheap fittings.
Basically do it right so you don't have to redo anything.
Old Feb 16, 2010 | 09:30 AM
  #365
XeroX's Avatar
Hella internets
I can vouch on this...Lucky for me the only thing i really cheaped out on was my TT, and go figure THAT crapped out on me lol
Old Feb 16, 2010 | 10:01 AM
  #366
VQ'ed's Avatar
I wonder why you guys go on such big turbochargers for rmt applications. HX35's seems big to me... I was planning for:
T04B compressor wheel: 48.4 / 69.9 mm 48 "S" Trim
compressor housing: 0.60 a/r T04B
center section: oil cooled journal bearings
Turbine wheel: 68 trim (stage1)
Turbine housing .48 a/r (.63 a/r upgrade available for 280+ HP)
http://www.blaastperformance.com/big.php?ref=90
Old Feb 16, 2010 | 10:24 AM
  #367
Kevlo911's Avatar
Kevlo for President
I start building boost around 3000-3500rpm. Once I wrap the bpipe it will be closer to 3000. That is perfect for me. Plus it is a great turbo for the price and leaves VQ30's room to play with.
Old Feb 16, 2010 | 10:49 AM
  #368
VQ'ed's Avatar
Compared to the T04B im looking for, is the hx35 A lot bigger or a bit bigger??
I know streetzlegend built his first rmt system with one.
Old Feb 16, 2010 | 12:55 PM
  #369
streetzlegend's Avatar
I had a t04B and I hated how it spooled up, pretty slow. the hx35 spool up in comparison is day and night, sometimes I go into boost without even noticing it. HX35 is not a big turbo, matter of fact at 15psi I am already running it out of efficiency, the t04b .69ar turbine housing i had was actually bigger than the turbine housing of the hx35. The compressor on the other hand is alot bigger on the hx, so you not only get awesome spool up but you also get alot more flow into the motor.
Thats almost exactly the same turbo I had (the one ur listing), I wouldnt get it just because how it spooled up, although once I had it on 16psi on the vq30 it was making good power(didnt dyno but was pretty noticible up in the 300s had to be). Being RMT does not make a significant difference in spool up vs. front mount, when done properly. In physics yes it does make a difference on paper, but in pratice its not really noticible, I was spooling the t04b the same way my friend with a 5sp was spooling it on his front mount setup.
Old Feb 16, 2010 | 01:56 PM
  #370
VQ'ed's Avatar
Thanks for your opinion, you have a lot of credibility from your previous experiences with different setups. I like sharing infos with people who know their stuff. Check this site:
http://www.blaastperformance.com/index.php
Which one would you suggest for a low boost (8psi)/hi response setup??
I'd like to have boost around 3500rpm and looking for full boost around 4500rpm.
I consider using a obx 2.5inch remote flange like this one:
http://cgi.ebay.com/ebaymotors/OBX-S...Q5fAccessories
Am I on the good path??
Old Feb 16, 2010 | 06:22 PM
  #371
Well may I suggest to start a thread about your build, that way we dont fill this thread with a lil bit of offtopic information and also you can keep your own records of stuff on ur own thread. id be more than happy to share the little knowledge I know.
Old Feb 17, 2010 | 05:51 AM
  #372
VQ'ed's Avatar
Yeah, sorry everybody, i agree. didnt mean to thread jack. thanks
Old Feb 18, 2010 | 01:05 PM
  #373
Kevlo911's Avatar
Kevlo for President
New muffler is on, sounds nice and quiet.
Old Feb 18, 2010 | 09:13 PM
  #374
Fking told you!
Old Feb 22, 2010 | 08:38 AM
  #375
XeroX's Avatar
Hella internets
Lol what did you have on before??
HAHA, when i had my straight thru muffler it was rediculous...i didnt even drive the car to the muffler shop i got it towed cause it was so loud
Old Feb 23, 2010 | 07:58 AM
  #376
95BLKMAX's Avatar
It was a Magnaflow, 3" Offset inlet/ 3" center outlet.
Old Feb 23, 2010 | 10:06 AM
  #377
Kevlo911's Avatar
Kevlo for President
I get my rim repaired tomorrow, car is almost ready to be reliable!!!!
Old Feb 23, 2010 | 01:00 PM
  #378
XeroX's Avatar
Hella internets
I had a vibrant dual tip straight thru type...what garbage that was...thank god i got it with the kit an didnt buy it lol
Old Feb 23, 2010 | 01:39 PM
  #379
liqidvenom's Avatar
brotherhood of tq
kev.... http://www.turbobygarrett.com/turbob...1_731377_1.htm
its the only smart thing to do.
Old Feb 23, 2010 | 02:20 PM
  #380
Kevlo911's Avatar
Kevlo for President
One day with the big motor car
Old Mar 8, 2010 | 03:12 PM
  #381
Kevlo911's Avatar
Kevlo for President
440's are on, charge pipe is off lol... again
I got the RC 440cc injectors on, surprisingly the car turned on the first time.
Did a quick tune so the car could run. Went for a drive, hit 5psi in third and the charge pipe slipped off again... UGH!!!!!!!! I will try to fix it tomorrow but all is well
Old Mar 8, 2010 | 03:32 PM
  #382
XeroX's Avatar
Hella internets
Depending on what kind of metal your maf adaptor is (im assuming thats where its slipping) You can weld a few beads on the lip of the piping so that the coupler doesnt slip off as easily...
alot of the 240 guys do this when they have similar problems and it works pretty good....
Old Mar 8, 2010 | 03:41 PM
  #383
Kevlo911's Avatar
Kevlo for President
Na it is slipping at my 2 - 3 coupler. I can fix it. I think I just made it loose when I was taking the intake out and putting it back in. I need to change the starter so I will fix it all then.
I would like to add that AMSOIL powerfoam is the ****!!!, stuff is amazing. Makes cleaning the car awesome.
ALSO I would like to add that the vq likes electrical tape I suppose lol, I accidentally dropped a small piece into the intake and I saw it on a valve, I could not reach it so I assumed the engine would just "eat it"
Old Mar 8, 2010 | 03:59 PM
  #384
EnervinE's Avatar
i has college
Old Mar 8, 2010 | 04:07 PM
  #385
Kevlo911's Avatar
Kevlo for President
Originally Posted by EnervinE
Lol yea it runs fine so I assume it is fine.
Old Mar 8, 2010 | 04:40 PM
  #386
XeroX's Avatar
Hella internets
i eateded all joor tapes.....om nom nom nomz
lol
Old Mar 8, 2010 | 06:17 PM
  #387
SiathLinux's Avatar
There is barely any shaft play, less than 1mm in any direction. I will see how the condition is of the turbo that will come with my kit. How would I go about cleaning this thing? Carb cleaner should be fine for the seals and such I believe. Also how do I make sure all the oil is drained from the turbo? I do no want to have anything mix.
None of the fins are bent but it might look like it with my ****ty cell cam
Although they aren't bent, I'd suggest bringing it to a place near me...http://www.dieselspecialists.net/index.html
Diesel Specialists, Inc.
850 Sunshine Lane
Altamonte Springs, FL 32714
Phone: 1-800-785-0775
Fax: 1-407-788-2028
Local Calls: 1-407-788-0775
Hours of Operation: Monday - Friday 8:00AM to 5:00PM EST
When I had my Ford Thunderbird TurboCoupe they did me right, I recommend them for anything turbo.
Old Mar 26, 2010 | 07:27 AM
  #388
Kevlo911's Avatar
Kevlo for President
Still having this one GAY problem. Car turns off randomly at idle.
I think it is either the MAF or the TPS. Any ideas? I am going to clean the MAF again this weekend but other than that I dunno what to check
Old Mar 26, 2010 | 07:49 AM
  #389
Kevlo911's Avatar
Kevlo for President
I also just ordered a nice brass check valve for the PCV system. Keep this engine runnin 4eva!
Old Mar 26, 2010 | 07:50 AM
  #390
liqidvenom's Avatar
brotherhood of tq
does the car just shut off or does it stumble and go off?
Old Mar 26, 2010 | 07:52 AM
  #391
Kevlo911's Avatar
Kevlo for President
Just turns off. AFR is normal. No bouncy idle or anything. Just turns off.
Old Mar 26, 2010 | 09:19 AM
  #392
XeroX's Avatar
Hella internets
sounds like something related to ignition maybe?
Old Mar 26, 2010 | 11:56 AM
  #393
VQ'ed's Avatar
men, such a jack-in-the-box car project you have.
best of luck to get it running properly.
keep it boosted!!
Old Mar 26, 2010 | 12:34 PM
  #394
Mine has done that, made sure maf plug was in all the way, and never did it again.
Also, when i was a newb, the reason I joined this forum was to figure out why mine shut off and wouldnt turn back on. Turned out to be the cam pos sensor.
Old Mar 27, 2010 | 10:34 AM
  #395
XeroX's Avatar
Hella internets
What's a jackin the box type car?
Old Mar 27, 2010 | 10:40 AM
  #396
Kevlo911's Avatar
Kevlo for President
Cleaned the maf again, still some oil residue in the pipes. UGH, I really dont wanna remove the IC and all the pipes lol.
Over the summer I might just drop/upgrade the IC and then wash out the pipes while they are on the car.
Also I have the code 1001 for the front O2, I wonder if it is somehow related
Old Mar 27, 2010 | 10:53 AM
  #397
perkman87's Avatar
does your car ever run full potential... figure it out i want to see vids of you doing 2nd gear rolls and loosing traction!!!!
good luck
Old Mar 27, 2010 | 01:01 PM
  #398
Kevlo911's Avatar
Kevlo for President
Lol had to change a fuel line hose and I replaced the clamps as well. Car is idling smooth I will prob go for a drive soon. and will report back
Old Mar 27, 2010 | 01:09 PM
  #399
Kevlo911's Avatar
Kevlo for President
So far car is running fine NA, but under boost it was NOT smooth what so ever. I am going to assume it is the tune. But it was weird.
Old Mar 28, 2010 | 07:57 AM
  #400
Kevlo911's Avatar
Kevlo for President
What cleaner/degreaser do you guys recommend to clean my intercooler/pipes while they are on the car? I think I should get something I can just pour in there, let it sit and then hose it out.
What do you guys think and which product?
