Kevlo RMT Turbo build -Works !!
Old Dec 8, 2009 | 02:12 PM
  #321
Kevlo911's Avatar
Kevlo for President
I have a T with the FPR vac line. It should be fine. I do not have any leaks.
Old Dec 8, 2009 | 03:18 PM
  #322
XeroX's Avatar
Hella internets
Like i said it might be irrelevent but worth a shot. Try to dedicate a line just for the BOV...i would think this as well as your FPR should not be T'd off together...I think i figured a way to dedicate vacum for both of those without T'ing them off to something else...
Maybe this is overkill, but i would think that its important...specially with your FPR and BOV
Old Dec 8, 2009 | 07:24 PM
  #323
maxgtr2000's Avatar
KH3 by popular demand
I have a ssq knock off and it needed a dedicated line, after that it worked fine no problems. The surging at lower psi doesn't do much it's at the higher boost where the damage comes in.
Old Dec 8, 2009 | 09:53 PM
  #324
streetzlegend's Avatar
Like mentioned, it is always best to have a dedicated line, and also coming from the largest port possible. The more diameter the more sucking power (that didnt sound right lol)
Old Dec 9, 2009 | 10:00 AM
  #325
XeroX's Avatar
Hella internets
Most preffer girth as well...
Old Dec 9, 2009 | 05:25 PM
  #326
Kevlo911's Avatar
Kevlo for President
I was wrong, the BOV is with tee'd with the MBC and Gauge. I am guessing that is not fine?
Old Dec 9, 2009 | 05:31 PM
  #327
MDeezy's Avatar
give it a dedicated line and see if the problem is resolved...
Old Dec 10, 2009 | 08:39 AM
  #328
XeroX's Avatar
Hella internets
So did it fix the problem?
Old Dec 10, 2009 | 09:52 AM
  #329
Kevlo911's Avatar
Kevlo for President
I need to add a line to put the other stuff on
Old Dec 10, 2009 | 10:41 AM
  #330
XeroX's Avatar
Hella internets
Lol, well i completey re organized all my vacuum lines when i did my VI swap...but we have hella extra places to run lines into the VI plenum...TOO many i thought, i think i have one hole still plugged that im not using...or maybe not? i cant remember..
There are alot of other sensors recieving vacum that can all be T'd off...check out some of those...Ill have to look how i did mine, i cant remember how its all setup to be honest...
Old Dec 21, 2009 | 05:12 PM
  #331
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
You get this fixed?
Old Dec 21, 2009 | 05:26 PM
  #332
Kevlo911's Avatar
Kevlo for President
I did re do the line but then I got a boost leak lol. So hopefully I get all the issues worked out this week so I can see if I need to install the new bov.
Old Dec 22, 2009 | 08:53 AM
  #333
XeroX's Avatar
Hella internets
U found a boost leak? Or you made one swaping the Vacuum line? How did you do that? lol
Old Dec 22, 2009 | 12:04 PM
  #334
Kevlo911's Avatar
Kevlo for President
Lol I had one at the turbo. I fixed a bunch of things today:
- Installed Nismo FPR
- Installed Summit Racing Fuel Pressure Gauge
- Changed turbo V-Band (old was broken)
- Cleaned BOV and piping after intercooler (too lazy to clean the intercooler)
- Fixed Oil leaks at turbo and changed the drain gasket
- Remounted the oil pump so it is quieter
- Redid PCV system
- Moved boost controller to the rear
So like 2 cap full of oil came out the BOV pipe lol so that might be why it was not working. The reason I had all that oil is because of the old turbo and old jets. Bunch of oil got in the pipes but most of that is gone now
I am too tired to go out and drive it but I will in a few hours. I need to change the oil and I am set to tune
Old Dec 22, 2009 | 12:09 PM
  #335
Kevlo911's Avatar
Kevlo for President
Oh and I will have pictures prob tomorrow.
Old Dec 27, 2009 | 03:48 PM
  #336
Kevlo911's Avatar
Kevlo for President
Drove some with autotune on. **** feels awesome at 5-6 psi. I need to do some more tuning. But I don't think bov is working still.
Old Dec 28, 2009 | 08:52 AM
  #337
XeroX's Avatar
Hella internets
- Redid PCV system
Great update!
I have yet to install a boost controller on mine, but can you explain why you "moved" it back to the rear of the car? Was it not making accurate adjustments far away from the turbo?
This is really wierd man...you and streetz having these issues with the SSQV...blehhh
When i got my kit from Maxboost, he gave me everything in a rubbermade container (a BIG one) and there musta been about 2 quarts of oil on the bottom of the container...EVERYHING was covered in oil. and the BOV had a bunch of oil in it too! I just wiped it down and mildly clean it, i didnt even really spray any carb cleaner in the BOV i just wiped it down and when i was first doing boost runs in the car, everything infront of the BOV was covered in oil haha. It just blew everything out after a few runs, i doubt the oil really does any damage to it, i think you may just have a defective part or something is up...
Oh well, get a new BOV i guess...
BTW, im jelous...I could never get that stupid autotune to work on my EU ughhh lol
Old Dec 28, 2009 | 09:42 AM
  #338
Kevlo911's Avatar
Kevlo for President
I am going on a 80 mile trip today so hopefully a few pshhhhhhh will clean out the bov
Old Dec 28, 2009 | 11:41 PM
  #339
MoncefA33's Avatar
How are you doing injector adjustments on the EU? I've heard if you're doing pulsewidth the auto tune will not work but if you switch to duty cycle it will work.
Old Dec 29, 2009 | 08:14 AM
  #340
Kevlo911's Avatar
Kevlo for President
So its pushing 7-8psi now. Feels AWESOME
Old Dec 29, 2009 | 08:35 AM
  #341
Kevlo911's Avatar
Kevlo for President
Autotune is working well. I just upped the BASE FP to about 42. This makes the under vac psi above 50. And with the 1:1 boost/fp increase. I shouldn't run lean in the boost range. Yesterday I was in the 12's and I dont think I stayed in boost long enough(car is quite fast) for the autotune to make corrections. I do NOT want to max out 3rd/4th just yet(still don't think BOV is full function).
The fluttering is alot less but I can't really hear a PSHHHHHHHH. So I am kinda confused. I def need to wrap my exhaust pipe all the way to the turbo to help the spool/turbo lag.
Now I just hope the clutch holds up I would have pics but I dunno where the camera is
Hwy mileage is still 27-32 mpg Depends if I am going 60-80mph.
Old Dec 30, 2009 | 08:56 AM
  #342
XeroX's Avatar
Hella internets
It has been so long since i have even touched the map i cant remember to be honest. Ill have to look at it tonight.
Old Jan 2, 2010 | 03:37 PM
  #343
Kevlo911's Avatar
Kevlo for President
So I have a boost leak. Dunno where it is
Now I can hear it spool but no boost.
Old Jan 3, 2010 | 09:08 AM
  #344
Kevlo911's Avatar
Kevlo for President
Keeps slipping at the 3" to 2" reducer. I am gonna add a T-Bolt clamp there (yes I know I should not have any hose clamps but damn they are expensive lol) Also do you guys have pics of how your maf is held? I believe since it moves so much that is why my pipe keeps coming out.
Old Jan 3, 2010 | 06:12 PM
  #345
maxgtr2000's Avatar
Mine has hose clamps since there are lips at those connections, the reducer has a t bolt clamp.
Old Jan 3, 2010 | 09:50 PM
  #346
maxcrazy01's Avatar
any internals done?
Old Jan 4, 2010 | 08:20 AM
  #347
Kevlo911's Avatar
Kevlo for President
No and I don't plan on it. With a good tune, this engine will push over 400hp at the wheels. The main problem is the transmission
Old Jan 4, 2010 | 11:33 AM
  #348
akurtzer57's Avatar
Im going for 400whp with my 3rd gen. I have a spare tranny which is lsd. I plan on sending it off and getting it treated. Just don't have the funds for that right now.
Old Jan 5, 2010 | 08:33 AM
  #349
XeroX's Avatar
Hella internets
Funny thing is with mine, my kit was setup using a landrover MAF housing, so i had a 2" to like 3.5" or 4" collector (whatever the hell it is) I never used the Land Rover Maf housing but i ended up putting a thick coupler on the maf and then the big 2-3.5" collector over that so i didnt have to buy another one..
I am suprised that your having a problem with yours since i did mine kinda ghetto...
What i ended up doing is making a bracket that holds the piping coming up from the bottom of the tranny that is bent toward the transmission bell housing where i thread a bolt thru the bracket and use one of the empty spots on the tranny...
Thats the ONLY thing i have holdint the piping in the engine bay and it works great...i figured since the tranny moves just as much as the motor that it was sufficient...
If i remember i will snap a pic of it tonight, but im sure its very similar to what you have im assuming...
Old Jan 5, 2010 | 09:40 AM
  #350
Kevlo911's Avatar
Kevlo for President
Yeah. I will try to get a pic soon.
Old Jan 5, 2010 | 03:39 PM
  #351
Kevlo911's Avatar
Kevlo for President
That is how it looks right now. The black coupler is the one that keeps coming out but I have a Tbolt clamp on the way for that
Old Jan 5, 2010 | 03:45 PM
  #352
XeroX's Avatar
Hella internets
What are you bolting the piping too tho? Did you make a bracket to the tranny like i did?
You should def have SOMETHING holding it once it goes past the tranny...
Also, boost leak may be coming from the cork gasket thing for your MAF adaptor...i had to tighten the CRAP out of mine, so much i cracked my MAF
Thank god for mighty puddy tho! haha it fixed it right up! and got rid of the leak lol!!
Old Jan 5, 2010 | 06:58 PM
  #353
Kevlo911's Avatar
Kevlo for President
No I don't have the pipes held to anything yet, that's why I was trying to get ideas Yea I wasn't sure weather or not I should keep the cork gasket or not. But that wasn't the leak problem.
Old Jan 12, 2010 | 07:02 AM
  #354
Kevlo911's Avatar
Kevlo for President
Might hit up the track this Saturday
Old Jan 12, 2010 | 03:13 PM
  #355
accordingtou's Avatar
VQ30 DE T
What #'s are you expecting?
Old Jan 12, 2010 | 04:03 PM
  #356
XeroX's Avatar
Hella internets
Yea best place i could c was using one of the extra unused threaded holes on the tranny....it looks like there is two but only one of them u can use (or should use i should say)
report back with vids and time slip!!!
Old Feb 2, 2010 | 11:32 PM
  #357
HomerMAC's Avatar
Donating i30 Owner
so this is a remote turbo? interesting but where the turbo is now.. wouldnt that be cause for water being picked up?
Old Feb 3, 2010 | 02:07 PM
  #358
Kevlo911's Avatar
Kevlo for President
It is in the back. The only way the filter can suck in water is if the filter is submerged
Old Feb 8, 2010 | 08:32 PM
  #359
93altima's Avatar
Turbo 4th Gen
what were your numbers?
Old Feb 8, 2010 | 09:06 PM
  #360
Yeah that was the fear everyone had when i first did the rear mount setup, been 3 years and I have driven through HEAVY rain (i live in Miami) and not a single issue, daily driver too
